Upgrade headlight?
Have you looked into the cost? I believe it’s about $5k for the factory triple beams.
No idea. Nothing on YouTube for this? Gut feeling is they would have a common harness, at least for the low/high beam inputs, but the triple beams have cornering lights that might not function on a car with the single-beam units.
I am in the market and triple beams are a must-have for the car I get.
I would think the connectors are very different as the tripple Beam has to talk to the car to rotate the lights in turns and as well as up and down. Base light does none of that.
Also, even base light has cornering lights on ES.
And thank you for the knowledge - didn't know base lights had cornering function.
the ones pictured in post 1 are aftermarket. they're still expensive.
yes base lights have side-illumination.
base main projection is shared with mazda 6, ford escape, etc. it's an off the shelf gen 1 K0IT0. same for gen 2.
Unless you just think they’re awesome looking don’t bother, I have bi level on my ES and tripe beams on wife’s IS and they’re almost exactly the same. If anything the bi level lights are slightly brighter at night and the triple beams slightly more even.
If I could have the $1,100 extra that they cost back I’d do it in a heartbeat.
F3Woody (08-18-23)
OEMs are not plug and play. The balast/functions are not the same.
I recall someone in a FB group doing this modification with aftermarket headlights just like that and they were happy about it. They posted pictures and said they were happy with the light output and pattern. I personally thought it was a bit of a mess in terms of light distribution as I have the real triple beam on my car. Can't beat OEM.
So apparently yes, a lot of people are completely happy blinding other cars so long as their own cars are bright and look awesome.
LexFinally (12-26-23)
BBQapple (08-20-23)
