DIY Transmission Fluid Change
I would not recommend the S unless you live really close to a service centre and have a second car. The Y is hideous and not a very good car overall (fun, great tech though), the 3 is OK, and definitely never ever buy an X, they are just so riddled with issues, even new 2023 ones.
I'm aware that this thread is about changing tranny fluid but feel obligated to state a few comments regarding Tesla. It seems that each time there is a news article about them they're A. catching on fire. B. Killing someone. C. Costing someone a fortune for parts. D. shoddy build and finish complaints. And how would you feel if you paid more than the cars are selling for now that they have been reduced to move?
And, BTW, none of the above apply to Lexus...
LS500Fan (08-24-23)
I don't really mind the fact that E46CT always bring out Tesla references to all threads LOL, I mean he has provided ton and ton of good info and tutorials here for the forums.
Just that it irritate a lot of people here sometimes. Unless it goes too far, we can't stop any body giving out their opinion. Maybe we just focus on the main discussion.
By the way, to OP, if you doing it soon can you provide a detailed write-up for us. I mean it sounds complicated on paper but hell, just drain out and fill in the same amount + a little more. What could go wrong , we not "flushing', just drain and fill right?
I have changed my oil, rotated tire (not anymore for those 2, I let Lexus do it so that the service showing up on Carfax and Lexus history for re-selling value purposes ), , change braked rotors and pads, I think I can do this . Maybe spark plugs next at ~80K miles
I've owned two S's. Before you even test drive one be sure to browse the owners forum for what sorts of issues to expect https://teslamotorsclub.com/tmc/forums/model-s.73/
LS500Fan (08-25-23)
Hey all, earlier in the year I picked up a 2019 Lexus ES 350 with around 60k to replace my wife's aging Pontiac. This was not our first ES as I have had a 2010 ES 350 since 2015 and it has been a phenomenal car. I have done all my own maintenance and repairs on my 2010 in the past but with this new car having a warranty I figured I would have the dealership service it so they could find potential issues that are covered by the warranty. Since the car has around 60k I told them to flush the transmission fluid but after hearing what they charge ($500) there was no way in hell I was going to let them change it when I could do it for a quarter of the price.
Is the process for changing the fluid more or less the same from the earlier models? Can I use Toyota WS ATF like I have in the past? I haven't had much luck finding a write up or instructional video with the 7th Gen ES so I figured not much has changed from the previous models. Either way here is the process I have used in the past to change my fluid:
- Take out transmission drain plug
- Take out the fill level straw
- Let fluid drain as much as it can, measure amount of fluid that was drained
- Put fill level straw back in hand tight
- Snug Drain plug, not torqued
- Fill transmission with the same amount you took out + half a quart extra
- Start car and cycle through the gears
- Let transmission fluid warm up until it gets to 104°F - 112°F
- Once the fluid hits the right temperature pull the drain plug and let the extra fluid run out
- Once fluid starts dribbling and not streaming put the plug back on and torque it to spec
Which dealer is that so we can stay away from . Every time I asked them to change my tran. fluid they all refused to do LOL
Your steps sound right to me, these 2 videos I found (you may watched them already) maybe helpful for you:
https:// www.youtube.com/watch?v=eRxSu4-4ojo
https:// www.youtube.com/watch?v=NUAuGmDGntY
bc6152 (08-26-23)
LS500Fan (08-26-23)
Get a Toyota dealership to do it, this is a well documented approach and will cost half as much. They really won't do a flush, but rather a drain and fill. Unfortunately, you need to do that 3 times on a regular automatic tranny to get all the fluid out. On the eCVT I have seen just a single drain and fill.
I like this 8 speed tutorial. It's a Camry, but shares the same tranny as the 2019 on up ES350. There is no accessible filter to change and no transmission oil pan. The fluid level checking temp starts at 95 degrees rather than 104 as on the previous 6 speed.
