How do I keep rear air conditioning vents turned on?
This button keeps re-selecting itself. When it’s selected like this the airflow to rear seats is disabled. I deselect it and within a day of errands it turns itself back on and there’s no more rear airflow.
That option has to be turned off with Techstream.
I wonder why Toyota/Lexus complicated such a thing, just leave it on and if we don't want air, we just close the (physical, left or right, or both) rear air vents our own.
Slowly stepping toward (unreliable) German engineer is what I see Toyota is doing
That’s to save energy.
^^^ This. It's not just the rear, it also affects passenger side as well. The same thing happened to me a few days ago taking my 9yr old nephew to basketball practice. Apparently due to its small size, the system did not detect his weight and did not engage the rear air flow automatically. Had to do it manually via the same screen. Although it is a good idea, the detection response should be improved.
I couldn't find the setting in the "Lexus Personalized Settings by Dealer" document. But apparently the Carista App has the option to do so (disable). I have the APP, so I would have to try and see. But according to the manual, even if the function is turned off, it's activated automatically after 1 hour of turning off the car.
It does not use the occupant sensor for detection but the infrared sensors mounted on the headliner.
If you disable the S-Flow option via Techstrean/Carista, it will not turn on automatically.
scubapr (09-07-23)
Excellent. Thank you! I'll personally prefer to keep it active. I understand that the rear vents most likely has a separate blower to help with air flow. So if there is no one behind (99% of the time) I prefer to conserve that energy/fuel.
Not sure if it applies to all trims and which year started, but my 2023 ES300h Luxury has it. My DW 2019 Rav4 has the "rear flow" setting as a dedicated physical button on the climate control area.
The 2023 ES does not have a physical button for this, only via multimedia interface.
Fuel Efficiency Question
Full disclosure I do not have this function on my vehicle. I think the OP has good information regarding the posted topic, so if you'll indulge me I'd like to hijack the thread for a brief detour.
I'm wondering how having the fan off in the rear, or a portion of the front for that matter, positively affects "fuel efficiency". If there is cooling needed in the vehicle a compressor is running (i.e. the drain on fuel efficiency vs it not running). Historically, the compressor is binary... on or off. Do the vehicles with this feature have a multi-speed compressor that runs it with more stress when greater cooling is needed or alternately, are there multiple compressors running (one for front and one for back)?
If not, then I believe the claim of improved fuel efficiency is false. My logic: All the blowers run off of battery power and what this function achieves is shutting off a zone's blower when someone is not recognized as present (i.e. not reducing the compressor impact on fuel efficiency).
You forum members are much more informed than I regarding the technical details on these types of issues. Without attacking me, please shoot holes in my argument. And I'm not interested in how Tesla does it Thanks!
Thanks for all the info guys, at least I know I’m not going crazy.
Partly I want it disabled because it’s super hot in Texas and the car cools off faster with all the vents working. Or maybe I have groceries or flowers in the back. Or maybe when I choose a setting I don’t want the car to second guess me and change it. It’s going to be 107F tomorrow and humid ugh!!
MAMOSKO (09-07-23)
