ES - 7th Gen (2019-present) Discussion topics related to 2019+ ES models
ES 300h 2024 wireless charger
Old 10-29-23 | 01:52 PM
grp52's Avatar
grp52
Originally Posted by Bankses350
I’m thinking of buying a new ES (not sure if 350 or hybrid). I don’t use the phone chargers and wonder if the charger in the 2024 is “always on” or can we power it off?
The Qi wireless charger in 2023 and later model year ESs has no physical on/off power switch. That said, the "new" charging pad has a device charging coil sensing function that will only turn on charging when a device's charging coil is within the charging pad's charging area.
From the 2024 Owner's Manuals (USA AND CANADA ONLY pdf version), page 286 for the ES 300H version and page 275 for the ES 250, ES350 version:
...If the charging coil inside a portable device moves outside of the charge area, charging will automatically stop. ...
There's also a diagram showing the charging area in the center of the charging pad with dimensions of approximately 2.8 inches by 2.4 inches.
When the charger power supply is off, the Qi logo will disappear from the 8/12.3 inch center display and the charging pad indicator light will be off.
Bankses350 (10-31-23)
Old 10-29-23 | 06:34 PM
july1988's Avatar
july1988
Why didn't they just have a power button there just like 19-22 models when it comes to tech, Lexus and Toyota always leave something behind to improve it later I guess LOL
Old 10-30-23 | 08:30 AM
tfischer's Avatar
tfischer
This is not a buying decision. Get the model ES that you want, and see how the charging pad deals with your phone.
It may not get warm, which might indicate no problem. Or, some phone cases are too thick to allow for wireless charging.
Or, just cut out a piece of black felt and place it over the charger: now you have a nice, soft, convenient shelf for your phone.
My problem with the charging pad was that it was too large for my (swell new) iPhone 15 Pro. On corners, the phone would slide around, clicking on the little raised edge. I solved that problem with a few little black adhisive-backed rubber bumpers so that the phone stayed put, and stayed aligned with the charging spot.
(I used the black felt to line the little pocket for my prescription sunglasses to make the inside surface a little softer.)
Finally, you say you don't use phone chargers, but with wireless CarPlay in the ES, you may find that you use your phone in the car more than before, and charging it wirelessly (slowly) doesn't hurt (I don't think).
montyf
ES - 6th Gen (2013-2018)
09-21-21 11:31 AM
jamestpc
12
08-19-18 05:56 PM
MEISEN529
01-04-18 01:55 PM
lotsof8s
06-13-13 11:50 AM
jeffofla
ES - 5th Gen (2007-2012)
17
09-10-07 08:22 AM
