Triple beam headlight and aftermarket sound system
My ES is equipped with triple beam headlights and it is pretty obvious when the conditions to turn on the cornering lights are met - the road edge, curb, corner, etc. perpendicular to the front fender gets brightly illuminated (in forward motion the side of the turn signaled or actual steering wheel indicated turn direction and both sides in reverse). The illumination is noticeable on street light lit roads and even more noticeable on pitch black, unlit roads.
scubapr has already posted a link with measured data, objective comparison between 2019 ES model year single beam and triple beam headlight versions.
With the 2022 ES changes in single and triple beam headlight assemblies, the IIHS 2022 Lexus ES 350 Vehicle Rating (and testing result data) (scroll down to the "Headlights" section) needs to be consulted for comparing single and triple beam headlight performance in 2022 and later model year ESs. Of particular note, the single beam headlights went from an "Average" 2019 version rating to a "Good" rating for the 2022 version. While the 2022 version single beam headlight measured test results still aren't quite up to either the 2019 or 2022 version triple beam headlight measured test result, the test data show the 2022 version single beam headlight has a pretty significant improvement in illumination performance over the previous single beam headlight version. The 2022 version triple beam headlight changes are more of a mixed bag - minor improvements in some area and minor degradations in others - which you have to dig into the "Technical measurements for this test" data for both the 2019 and 2022 versions to see what's changed in the illumination performance area.
If one really wants to get into the weeds of comparing IS and ES headlight illumination performances, IIHS also has 2023 Lexus IS Vehicle Rating (and testing result data) to assist in the comparison endeavors.
The following 2 users liked this post by grp52:
july1988 (12-12-23),
Mrbungle11 (12-12-23)
Adding Options
I got the triple beam headlights
Deff a must buy for me!!
They fill in the headlights so perfectly unlike the single being headlight, which the DRL strips is too long for that one projector light.
Looks beautiful with the lights on or off fortunately 99.9% of all ES owners has single been headlight so my car stands out
I always buy my Cars with a headlight upgrades ( if available)it just makes a whole difference to me or any light upgrade on a car.
I prefer the bi level headlights on the ES and find the triples remind me of a spider and are a bit busy and a little less “grown up” for my taste but I’m over 50. Probably my favorite headlight design was the E39 5 series BMWs with two round units with LED haloes.
Wife has the triples on her 23 IS350FS so guess we get the best of both worlds. I especially dislike the multi unit Acura headlights that look like 5 ice cubes.
It’s funny a lot of younger drivers seem to just want to change their cars. When I had a 2001 Acura TL years ago it came with dual exhaust and a couple guys in the forums changed it to a single tipped exhaust. If a car had amber lights, they wanted to change to clear.
My triple beam headlights has 360 lights when I put the car in reverse!!!
So good it makes me wanna slap my mamma!!!
cornering lamps are NOT the same as the things that angle on bends in the road. The triple beams do NOT have cornering lamps.
how are triple beams “far superior” to bi level LEDs of the same generation? My wife has. 23 IS350 with triples and I have a 23 ES300h with bi levels. The bi levels are actually a tiny bit brighter plus they have cornering lamps which the triple beams don’t have. I’ll take that over the road curve servo adjustment. What year is your wife’s RX if you think the triples are far superior?
The IIHS rated the ES with triple beams versus the ES with stock headlights in a variety of specific situations. The triple beams scored higher in some of them, particularly when curving to the left or when depending on the high beams to illuminate the left side of the road while traveling straight.
https://www.iihs.org/ratings/vehicle...oor-sedan/2022
I wanted them. I was spoiled coming from another car with exceptional headlights, and I'm old enough to appreciate all the help I can get.
I like them after years of ownership. I'm a cheapskate though when shopping for cars and always looking for ways to shave the cost😁
The hell is 360 lights LOL?
Tri look cool but bi's are just fine.
My local dealer plus 2 more within 100 miles had no stock with them. It was hard to find even 1 Luxury or Ultra Luxury. Between them I think they have 13 base builds in black / black or obsidian / black or white / black. I don't get it. Do buyers really want an all black interior? The 2 tones highlights the lines and design.
I am still learning!
Is it possible to add in the triple beam (OEM) if we buy a used 300h? Would we just get it from the dealer and have them install? Are they limited to certain model years only? Looking at model years 2015-2019.
Credit to @grp52
You are also looking at the 6th generation ES which is different from the 7th generation. Some parts may be interchangeable or more easily modified to work in a previous generation. Headlights in this case, will not be.
https://www.clublexus.com/forums/es-...l#post11628625
Credit to @grp52
Credit to @grp52
