Triple beam headlight and aftermarket sound system
#31
I know for a fact there are triple beam options from aftermarket available for the 6th gen ES, so that's a route you could take.
RudimentarySpoon (12-12-23)
#32
I still cannot believe that the tripple-beams are not plug and play since they have the same functions.
#33
I don't know how accurate prices are and I know it varies across different sources but here is one source:https://parts.lexus.com/p/Lexus_2022...114533J71.html
Over $3k just for the passenger assembly. It was a $1200 or less option when optioned onto the car. A steal.
#34
The stock lights can be "upgraded" with aftermarket parts. However, keep in mind while the aesthetics may be there the functionality and quality is most likely another story. I know there is someone out there who has a 7th gen ES and swapped out their traditional headlights for an aftermarket triple beam that looks like OEM and is happy with it. As good as it looks, the light output is completely off from OEM, as expected.
Good to know that the 6th gen has more options but meh, I will stick with stock for this car.
#35
Self Leveling
I think they look good but the self leveling is kind of a gimmick. Does it adjust for weight difference? Maybe hills with a good grade but not fast enough for bumps in the road.
#36
Based on the IIHS tests, only on the 2019 model year, the tri-led are marginally better than bi-led. From 2021-2023 they perform almost identical. Some will notice difference other do not. IMHO there's no point on changing them other than aesthetics. And I highly doubt any current aftermarket could have a better performance or functionality over the OEM.
LexFinally (12-13-23)
#37
If nothing else, could be worth $1,500 just to see the lights dance every time you start the car
#38
I had a 2001 LS430 years ago and loved the startup dance at night for the HID xenon lights. LEDs super white are definitely better but the blue xenon look was pretty cool back in the day.
#39
Funny the triple headlights are an option on any trim level and now $1215. I wanted them because my eyesight is not that good at night. I thought only the triples came with the cornering lights but 1st time I drove at night I noticed the bi-beams had it as well. Reminds me of my old caddy.
My local dealer plus 2 more within 100 miles had no stock with them. It was hard to find even 1 Luxury or Ultra Luxury. Between them I think they have 13 base builds in black / black or obsidian / black or white / black. I don't get it. Do buyers really want an all black interior? The 2 tones highlights the lines and design.
#41
But you're correct in that the much, much better steal is getting all the triple beam headlight hardware as a manufactured build option - 2024 (US) Lexus list price $1215.
#42
I personally agree with you about the all-black interior, with all respect to those reading this who have and love it. I think it's symptomatic of a larger trend across all makers. Since the start of the pandemic shortages, dealers and makers have concentrated their limited capacity on stocking the most noncontroversial and easiliy sold trim combinations. That's resulted in a lot full of cars that are all grey, black or white outside and black inside. I miss color.
I got my wife a red interior for her IS which I never thought I’d like but when I saw it in person I just had to have it!
#43
I’ve got black interior and like it, the dark brown “acorn” is also nice. I hadn’t had a black interior in years and kind of wanted one again. But it’s a bit dour for sure. What I don’t get is why Lexus made their current tan interiors with so much orange in the hue, it’s not for me the older more normal tans were so much more traditional.
#44
Yep the black “open pore wood trim” looks like a spray painted broomstick
Suppisedly it’s stained with a special black ink used in Japanese calligraphy but it sure looks like plastic to me. $500 option as I recall.
YumpinYiminy (12-14-23)
#45
From those diagrams one can see these additional features/functions to power and control in triple beam headlight assemblies that isn't present in the single beam headlight assemblies:
1. Headlight swivel motor
2. Headlight leveling motor
3. LIN bus for communication to items 1. and 2.
4. Headlight fan
Since there's more to power and control in triple beam headlight assemblies than in single beam assemblies, it shouldn't be surprising to find different headlight ECU parts are used to power and control the two types of headlight assemblies. For example, Front Right Headlight Control Module (with triple beam) and Front Right Headlight Control Module (without triple beam) - same headlight assembly location; different headlight ECUs for different headlight assembly types.
