Triple beam headlight and aftermarket sound system
Is it possible to add good , affordable brand triple beam headlights to my es350 and after market sound system.
what brands do you recommend?
No aftermarket beats the OEM triple beam. I've seen users install aftermarket triple beam and while the aesthetics might be there the light output isn't even comparable to OEM. In my opinion, if you're going to go triple beam, do it right and get the OEM ones.
Morimoto make some great headlights for the 4runner from what I've seen, maybe they have a Lexus ES set? If so, that may be the best "affordable" option out there imo. Morimoto makes good stuff.
For aftermarket sound system, that's a pretty subjective matter. It depends really on what type of music you listen to and how it sounds to you. It's definitely possible to, I just don't have any recommendations as I haven't gone that route as I find the base sound system to be pretty good overall after some fine tuning in both the car and my phone.
darkknightntpa (12-17-23)
Where to buy oem cheaper than dealership.
Any other place I can get oem triple beam headlights cheaper then dealership?
I can also give away in exhchange. My new oem headlights only 3500 miles used once I realized lace them with triple beam.
+1 or Morimoto. I've purchased two sets of foglights from Morimoto and they were stellar. One was for my 4th gen Acura TL and the other for my 1st gen Acura TSX. Both were a huge upgrade from stock.
There don't seem to be any vehicle specific lights that Morimoto offers for the 7th gen ES however. At least not that I can find on their website. I'm not sure what they'd offer anyways. To my knowledge, there are no OEM foglights for the 7th gen ES and the OEM headlights aren't easily upgradeable.
Wife has a 23 IS350 FS with triple beams and I have a 23 ES300h with the single lens “bi levels” and I can tell you the triples aren’t brighter or better.
If anything my bi levels are a tiny bit brighter and the triples are a tiny bit more even. It took probably a month to see the difference. You’re not missing anything, unless you just like the way they look to other motorists.
Also itbsucks the triples don’t have cornering lamps like the bi levels. For that alone I prefer the bi levels.
Anyway OP, I'm 99.9% sure (bi / tri) headlights are not interchangeable. There's a full thread comparing them:
https://www.clublexus.com/forums/es-...eadlights.html
You can definitely upgrade speakers & subs, but it's not so DIY friendly. Checkout this thread:
https://www.clublexus.com/forums/es-...-speakers.html
Are you referring to the feature were headlights move as you turn? If so, I can confirm the triple beam headlights on my 300h have that feature. It lights up the path you're taking in advance and it's very noticeable.
The following 2 users liked this post by ATL350:
BBQapple (12-12-23),
dklanecky1 (12-12-23)
Upgrading audio is possible but not plug and play. Speakers, amps and head are all matched in a proprietary manner. Yes you can put in what you like and maybe your ears can't tell that it's not matched. Personally, I had replaced my dash tweeters with aftermarket which gave me brighter sound/efficiency. A little mounting customization was needed. I also put in a powered 10" subwoofer in the trunk from Rockford Fosgate. I just connected the inputs to the existing sub inputs. Very simplistic, but it satisfied me and was a DIY.
how are triple beams “far superior” to bi level LEDs of the same generation? My wife has. 23 IS350 with triples and I have a 23 ES300h with bi levels. The bi levels are actually a tiny bit brighter plus they have cornering lamps which the triple beams don’t have. I’ll take that over the road curve servo adjustment. What year is your wife’s RX if you think the triples are far superior?
l
l
ifnyou were to drive current models with both kinds of headlights back to back at night like my wife and I own, you’d see the triple beams are not noticibly better on the road and in fact the triples seem a little bit less bright. And I always miss the cornering lamps when I drive my wife’s triple beam car at night I prefer the bi levels on my car.
i would happily trade her triple beams for bi levels with cornering lamps even if I couldn’t get the $1,000 back. Maybe if we lived in the hills with narrow winding roads I’d appreciate the adaptive curve triple beams more but in the city they’re slightly inferior.
scubapr (12-12-23)
cornering lamps are NOT the same as the things that angle on bends in the road. The triple beams do NOT have cornering lamps.
I don't know the difference between the Bi "Cornering Lamps" and the Tri "Adaptive Curve". But I have the Tri in my 2023 ES 300h and I do notice the illumination to the sides when turning or turn-signal. You can see the effect in the below video at 10:08 to 10:20
Myshkyn (12-12-23)
I got the triple beam headlights
Deff a must buy for me!!
They fill in the headlights so perfectly unlike the single being headlight, which the DRL strips is too long for that one projector light.
Looks beautiful with the lights on or off fortunately 99.9% of all ES owners has single been headlight so my car stands out
I always buy my Cars with a headlight upgrades ( if available)it just makes a whole difference to me or any light upgrade on a car.
to the op what year headlights your looking for?? there’s two version available!!
