Which trim/year has most of these features?
5th Gear
Hi, I'm looking to buy a >2019 ES, and there are a lot of options that are not available on all trims and model years, so I was wondering if I could get some advice on which trim/model year would check the most boxes.
I'm looking for:
Or I find a 2022+ ES 350 f-sport, but those are not AWD
Thanks!
Edit: bonus questions:
I'm looking for:
- Red interior is a must (only f-sport trims?)
- Android auto is a must, ideally wireless
- Heads-up display (only ES 350?)
- AWD (only ES 250?)
- Touch screen (only 2022+?)
- Kick-activated/automatic opening/closing trunk (not that important honestly)
Thanks!
- What's the interior width in the backseats? Since the back seats don't fold down, would it be possible to fit a snowboard across the backseats, diagonally somehow?
- The 2021 I drove had the HUD with turn by turn for navigation.. using Lexus navigation. But now I read online that this HUD turn by turn feature doesn't work with android auto + google map/waze, is that right?
- Red interior is F sport exclusive
- Android Auto wireless is standard with 12.3" Navi package if I recall, and wireless as well, iirc
- Option
- Only the ES 250, FWD otherwise
- 2022+, yes
- option
I have a 22 F Sport and the only thing I did was to buy a dongle that made it AA wireless. No HUD, not a fan of it, but would be ok if I did have it. The power trunk I didn't think I'd find it necessary, but it's been clutch, really like the feature. The only thing about it I hate is that you can't close the trunk from the inside or keyfob, what a misstep by Lexus there.
- Option
- 2022+, yes
- option
IMO I think the reason you can not close the trunk with the remote or the button in the car is, if you had a over sized item and the trunk closed on it would damage the trunk lid and or the item in the trunk.
That’s not the case because the trunk lid automatically stops if hits something while closing.
The rear seat pass through into the trunk is a rectangular opening with a diagonal of approximately 28 cm. A search result indicates the standard width of a snowboard is 25 cm. So, if your snowboard isn't to thick you might be able to fit your snowboard through the trunk pass through by tilting it.
According to Lexus official specs, the rear hip room is 54.3 inches; however, if you measure the width above the rear seat door arm rests the maximum width is approximately 58.5 inches. For what I think will be the maximum diagonal measurement in the rear seat area, from the angle vertex of the footwell bottom and outer vertical footwell edge to the opposite side's top of the window glass where it seats into the door's window frame the distance is about 65 inches. (To get the maximum diagonal, the front seat on the side with the upward pointing end of the snowboard will be restricted on how far to the rear the seat can be adjusted. The front seat back tops curve to the rear and that can interfere, I think, with getting a snowboard positioned at the maximum diagonal extent.)
You probably should subtract some from those measurements to allow for some padding of the snowboard ends so as to not damage the interior from hard snowboard edges pressing/rubbing on the interior as you're driving down the road.
trexiic (12-23-23)
- Option
- 2022+, yes
- option
- Option
- 2022+, yes
- option
dezymond (12-23-23)
5th Gear
Oh wow thanks for all the measurements! We'll buy a bag for the snowboard as to not scratch/soil anything in the back, but as for the measurements it should fit.
I still have to figure out whether Google Maps on Android Auto will work with the HUD.
For the touch screen / wireless AA I suppose I don't really care, so I'll just have to find a 2020-2021 f-sport model with the options I need.
If you go to My Lexus RESOURCES, select a ES 300h or ES 350 model type and 2020 model year, and click on the "SUBMIT" button to update the web page and the links to the appropriate resources you'll see there's two versions of all the manuals - "... THROUGH SEPT. 2019 PROD. ..." and "... FROM 0CT. 2019 PROD. ...". The "... THROUGH SEPT. 2019 PROD. NAVIGATION AND MULTIMEDIA SYSTEM OWNER'S MANUAL" only includes Apple CarPlay; whereas, the "... FROM OCT. 2019 PROD. NAVIGATION AND MULTIMEDIA SYSTEM OWNER'S MANUAL" includes both Apple CarPlay and Android Auto.
P.S. The above applies to US sold ESs. For Canada, there's only one 2020 Navigation System Owner's Manual and it only includes Apple CarPlay. I would assume Canadian sold 2020 ESs would track the same Android Auto availability as US sold 2020 ESs but there's nothing in the Canadian manual versioning to show Android Auto becoming available at some point during the 2020 model year.
Depending upon how you're planning to stow your snowboard, a thin cloth or ballistic nylon bag may not have sufficient padding on the hard, sharp corner edges to protect the door card materials from damage.
It's great you're narrowing down the year and options. I'm looking for an ES350 UL. I imagine you'll find the same as I, there are only a few spread across the country. With patience and flexibility we'll both find the right one. Best wishes.
5th Gear
Yeah but I'm not in a hurry, I'll wait for the perfect trim/year over the course of the next year. Now I know what I'm looking for, so I won't have to wait for a combination that doesn't exist.
SI I'll keep an eye on those 3 trims and wait for a good deal.. and yeah, in Canada - Quebec, there's like 1 or 2 available at a time, so I'll have to wait a bit haha
- 2020-2021 250: the 250 is AWD and has the f-sport trim in those model years.
- 2020-2021 350: same thing mostly, but no AWD although better performance and trunk capacity
- 2022+ 350: touch screen/wireless android auto
I'm looking for:
Thanks!
I'm looking for:
Thanks!
