ES - 7th Gen (2019-present) Discussion topics related to 2019+ ES models
Brief Oil Consumption Survey
Old 02-01-24, 08:28 PM
  #31
carsareus
carsareus's Avatar
Zero oil consumption on my 2020 ES350 UL with 30K miles. I do however have my oil changed every 6 months or 5K miles regardless.
Old 02-01-24, 08:32 PM
  #32
carsareus
carsareus's Avatar
Originally Posted by Shaboom
Could changing brands of motor oil possibly decrease oil consumption. I use Castrol Edge full synthetic. Amsoil?
No difference at all from how I understand the problem. Oil consumption is usually caused by a stuck oil ring due to sludge buildup caused by not changing the oil soon enough. When I say soon enough, I mean by exceeding the recommended Toyota oil change intervals.
Old 02-02-24, 09:13 AM
  #33
703
703's Avatar
at the end of the day, your consumption figure is too high. There should be no top up required between oil change intervals.
the “acceptable” limits are written by accountants and lawyers at Toyota and not engineers.
Burning oil can foul your spark plugs, leading to engine misfires. Plus, it can damage your catalytic converter and oxygen sensors over time. This is all after your warranty expires.
TerryNVA (02-03-24)
Old 02-02-24, 12:51 PM
  #34
Shaboom
Shaboom's Avatar
Will continue to monitor my oil levels very carefully and frequently,, especially considering your above explanations and admonitions. Thank you.
JayCee49
RX - 3rd Gen (2010-2015)
36
05-18-23 10:27 AM
Shaboom
30
05-09-21 07:18 PM
Poppa
ES - 6th Gen (2013-2018)
10-02-20 12:50 PM
ddvette9
01-17-17 08:39 AM
Quick Reply: Brief Oil Consumption Survey
