New owner of a 2020 es300h seeking advice and tips.
I disable the seat movement. I don't need all that wear and tear on the motors. i can get in just fine
My Model Y has that feature too. i disable it.
It slips over the seatbelt buckle so that minimizes a lot of movement, but just like any aftermarket solution, there is going to be a bit of play or even it popping up a bit more if you're moving your seat up and down more. That being said, it doesn't scrunch all the way up to the point where it's useless, we're talking maybe a cm of movement.
Too bad the apple car play doesn't work with the USB connections in the rear seat area.
