Interior Lighting question
My 2019 ES350 (which I just bought) has very dim interior lights when the doors are open. I assumed these could be "turned up" but the owner's manual has no mention of it.
Am I wrong? Is this the best Lexus can do?
If so, should I replace with LED lights? I did that in my 2012 ES and that were the treat.
Thanks.
Thanks.
They are all LED, but that is what it is. I assume your interior is black?
Did you increase the brightness of the footwell LED-s?
I usually use this website to reference bulb size/type but it says not serviceable by user
The user @JamesAZ has a thread on the upgrade process for those brave enough....
7th Gen Lexus ES Ambient Lighting Kit Installation
Interior lights is the first think I look to change whenever I get a new car but I think the LED chip is soldered to the housing itself? Could be wrong on the technical part but almost positive you can't change any bulbs, other than the amber lights in the headlight
For reference, if you look at the lexusguide.net Lexus ES (XZ10) Service Manual's Lighting System (for Gasoline Model) - System Diagram (scroll down to the web page's bottom for the "HEADLIGHT ASSEMBLY CIRCUIT (for LED Type Turn Signal Light)" and "HEADLIGHT ASSEMBLY CIRCUIT (for Bulb Type Turn Signal Light) (for TMC Made)" [and (for TMMK Made)] system diagrams) you can see the bounding box for the Triple-Beam LED headlight unit assembly; i.e., "HEADLIGHT ASSEMBLY CIRCUIT (for LED Type Turn Signal Light)", includes the LED symbols labeled "Turn Signal Light" and "Side Marker Light". Whereas, the bounding box(es) for the Bi-Beam LED headlight unit assembly; i.e., "HEADLIGHT ASSEMBLY CIRCUIT (for Bulb Type Turn Signal Light) (for TMC Made)" [and (for TMMK Made)], does not include the incandescent light bulb symbols labeled "Turn Signal Light" and "Side Marker Light". (There's a hybrid model version of the linked web page but there's no difference in headlight unit assembly diagrams.)
G1H1 (02-21-24)
Image from: LS500Fan
