ES - 7th Gen (2019-present) Discussion topics related to 2019+ ES models
Gas Tank Overflow!
Old 05-24-24, 10:50 AM
RocketMan295
RocketMan295's Avatar
Default Gas Tank Overflow!
Thought I’d put this out there so no one else makes the same mistake I did last night: Went to fill the tank on my new ES300h, needed at least 10 gallons. I popped the (Matador Red Mica) door open about 2 miles before reaching the gas station (my stupid habit). The non English speaking attendant opened the cap and began filling the tank, walked away, and the nozzle cut off with a splash after about 2 gallons went in. He came back started it again and the tank overflowed all over the quarter panel and rear left tire. Probably a pint or two of gas. A comical exchange of words, he said tank is full, I said pump is NG. I quickly paid, high tailed it home to wash the car and tire with soap suds. The takeaway: Read your Owner’s Manual (page 174) about refueling! Never pop your tank door ahead of the gas station! The manual will tell you exactly why!
scubapr (05-24-24)
Old 05-24-24, 11:05 AM
july1988
july1988's Avatar
I have so many questions
The following 3 users liked this post by july1988:
ATL350 (05-25-24), bc6152 (05-24-24), landonm86 (05-25-24)
Old 05-24-24, 11:14 AM
scubapr
scubapr's Avatar
Overfilling can have serious consequences/damage to the EVAP system; not just the panel paint. That could cost you $$$ in repairs down the road. If possible have it check.
RocketMan295 (05-24-24)
Old 05-24-24, 12:06 PM
mikemu30
mikemu30's Avatar
Received 2,542 Likes on 1,815 Posts
What does the overflow have to do with popping the tank door before you shut down? Don't make us open up the manual😉 especially since page 174 in my manual refers to driver support systems.
bc6152 (05-24-24)
Old 05-24-24, 12:18 PM
scubapr
scubapr's Avatar
Just checked my manual. I suppose it's about this interesting note(s):
The following 2 users liked this post by scubapr:
bc6152 (05-24-24), mike995134 (05-25-24)
Old 05-24-24, 01:26 PM
RocketMan295
Default Thank you!
That video was spot on. As well as the text of page 174 (Some day I’ll learn how to attach something, I’m tech-illiterate) Bottom line: There’s a valve somewhere in the filler neck. I can’t prove it, but somehow I think there’s more to simply popping the door than meets the eye. From now on, I’ll follow the owner’s manual instructions. Just like I tell my kids to do!
The following 2 users liked this post by RocketMan295:
FastDawg (05-25-24), scubapr (05-24-24)
Old 05-24-24, 02:31 PM
bc6152
bc6152's Avatar
Received 1,300 Likes on 905 Posts
I never open the fuel filler door ahead of time but I thank you for this good information as I'm sure it will help someone who did what you did. Had no idea about the interior valve timing.
The following 2 users liked this post by bc6152:
LatinLS430 (05-24-24), scubapr (05-24-24)
Old 05-24-24, 02:32 PM
scubapr
scubapr's Avatar
Very interesting. Just found this (A25A-FXS) EVAP diagram. Maybe that's the filler close valve referenced in the manual.
Old 05-24-24, 02:45 PM
ESh
ESh's Avatar
Received 1,013 Likes on 760 Posts
That’s all because of the EVAP system. On Hybrids it is a very complicated system.
Old 05-27-24, 08:39 PM
JeeX
10th Gear
JeeX's Avatar
I just did my first refueling today. Luckily did not pop the fuel door before hand. Very good info.
Old 06-02-24, 03:36 PM
Wilson2000
Wilson2000's Avatar
Interesting thread regarding the valve activated by the fuel door. Another good reason to be on CL!
I've known about the other issue, not overfilling, since 1990. I bought my dad's 1985 MR2 and wasn't happy with the small fuel tank, so I routinely topped it off. That is, until my evap system failed and indicated I needed a new charcoal canister (not cheap). I cutout my practice of topping off, and the check engine light eventually reset, and never reared its ugly head again!
scubapr (06-03-24)
Old 06-03-24, 06:20 AM
hotwings
hotwings's Avatar
The day will come when the owner's manual under refueling states: "See your Lexus dealer"
ptthere (06-05-24)
Old 06-03-24, 08:56 AM
Wilson2000
Wilson2000's Avatar
Generally, the design of this fuel fill valve being activated by the opening of the fuel fill door seems suspect. It's fine 99.99 % of the time, but not always as OP found out the hard way. These systems need to be 100% fool proof!
Old 06-03-24, 09:50 AM
scubapr
scubapr's Avatar
OP pressed the fuel door opener switch about 2 miles before reaching the gas station. Manual states to complete refueling in 30min since the door switch is depressed. Maybe there was some traffic or something else failed. But given that refueling could be done in less than 5min; I cannot imagine most people opening their fuel door 15-20 min before arriving to a gas station.
Sometimes is hard to imagine all possible scenarios by a user (no offense to OP). Perhaps the auto close is there to protect against something else worst to the engine.
Owners manual clearly specifies this, but most people rarely read them.
Still very interesting thread / issue.
Old 06-03-24, 09:58 AM
ESh
ESh's Avatar
The fact of the matter is this, if you open it 25 minutes before you put the nozzle in, you close it and open again and then you have another 30 minutes to jerk around.
scubapr (06-03-24)
Quick Reply: Gas Tank Overflow!
