Hitting Knee/Shin upon entry
I'm a little over 6 feet with long legs. I've used the bostonsnow method for decades and never have had a problem with knees making contact on the entry. It might not be for everybody, but it works for me.
I’ve never hit my leg on entry (22 ES350 UL), but I do frequently thunk into the side bolster, which I think is just too damn big, a problem I haven’t had in any other car, I’m not a particularly big guy and maybe it’s the way I enter this car, but the modern “need" to have intrusive and “aggressive” bolster to hold me in my seat during all of my high speed curvy roady driving, you know, just like the automotive press writers think we do every day is ridiculous.
For the first time, in my life I was analyzing how do I enter my car.
I stand almost parallel to the door pillar and then extend my right leg full straight (180) into the middle/rear of the floor mat; then I bend my knees to slide into sit. I do have the easy exit/entry; but regardless I have entered with that feature off and never have hit the dash edge. Although 50yr old, I'm very athletic with strong legs and don't have any knee problems (only back). Maybe that's why I have never had the OP issue.
I did try the OP method/picture and definitely my knee hit that edge. No way I could enter that way regardless of easy exit/entry mode.
Anyway, maybe OP should start thinking about switching car. He could get a knee injury if hitting hard enough. IMHO a car should work for you no the other way around.
Is it me, or other 7th gen Lexus ES300/350 and Camry owners experience the same? 6 times out of 10 when I enter my ES300h '22 vehicle on the driver side, I end up hitting my knee or shin to the dash edge near the door. It is annoying and sometimes somewhat painful. If this is a bad design and enough people are experiencing it, Lexus should know about it and remedy it in their future revisions.
(Verse 1)
You put your right leg in,
You take your right leg out,
You swing it round and round,
And try not to shout, "Ouch!"
(Chorus)
You do the car seat shuffle,
And you turn yourself around,
That's what it's all about!
(Verse 2)
You put your left leg in,
You take your left leg out,
You twist and turn and bend,
And hope you don't fall out!
(Chorus)
(Bridge)
You grab the door and pull,
You push with all your might,
You finally get yourself out,
And say, "What a fight!"
(Chorus)
If nothing else, humming the tune will distract from the pain!
I will be expecting royalties!
gcvt (06-07-24)
scubapr (06-07-24)
another idea - looks like you are entering with your foot going in first, then leg and hips/butt later.
if you have enough room to open the door wider, you can turn sideways to the car, put butt down on the seat first, then swing the legs in after that. that way have sat down first, your knee will be in a lower position when you rotate your legs in.
scubapr (06-07-24)
I do, but, having tried it out when I first got the car, I didn’t like it as the seat was too low and far back so I felt like I just fell into it. I also didn’t like getting out from that position. But that’s just me.
scubapr (06-07-24)
Lexus's puddle lights are so pretentious they practically whisper, "Darling, you've arrived." That's okay, though; I've got 'em, too!
It seems you enter the vehicle with your leg almost perendicular (90 degrees) to the floor which puts your knee very close to the dash. I always get in with my leg extend out so it is more flat and at an angle approaching being parallel to the floor. This way my knee stays low and never gets close to the dash. As I am getting in I put my right foot close to the foot rest at the firewall and at the same time I grab the steering wheel and pull myself into the car. By grabbing the steering wheel, I also prevent my back from rubbing against the side bolster of the seat. With this method I also minimize wear on the side bolster. In previous cars I have had premature wear on the the seat side bolster which for me is not a good look. Hopefully I save my seat and knee at the same time.
Newgsman, you are on the money. I also did some variations on the way I enter the car and putting my right foot further inside (toward the center) and in an angle makes the problem go away. But muscle memory retraining may take some time. Especially when I am in a hurry, which is when I hit my knee to the dash most. Lol
Altogether as someone else said, it's a first world problem, or annoyance as I originally characterized it. And better yet it doesn't seem to be a common problem, at least with the members of this forum.
scubapr (06-11-24)
Tayydawgg
01-30-23 11:07 AM
WhatYaGot
03-05-19 06:08 AM
ajschoen
04-16-17 05:17 AM
