Upgrading Door Speakers - 2020 ES350
Hello!
I would like to upgrade the sound, but unsure what speakers to use (or if I even should).
I have the Mark Levinson system.
I'm finding mixed speaker sizes online.
-I'm seeing Front Door speakers as a 6"9", but also seeing some sources that suggest 6.5"
-I'm seeing 3.5" for dash center and corners (which I believe to be the case per several sources)/
-Rear door I'm seeing 6"x9".
Could someone confirm these sizes? I'd rather not open up the door just yet to confirm. I'd want to have the speakers with me to replace so I only have to take the panel off once.
ALSO another important question is.. Is it worth it? Are the MK speakers already top-tier?
I'm liberal with my spending when it comes audio, so I will be purchasing higher quality speakers.
Want to make sure everything is compatible with the amp system supplying the speakers works with any speakers.
Thank you!
Thank you!
Bocatrip
03-08-12 03:47 PM
