Quick way to turn AC on or off?
It seems that to turn AC on or off you need to go through a couple of screens and menus before getting to the AC button under the climate menus. Is there any short cut way to do this. I don't like to use AC on all the time when I'm in the car so I like to turn it off every now and then. I find that it is cumbersome to go through all the different screen menus before getting to the virtual AC button on screen. I like the old days when there was an AC button on the dash for a quick on or off. Does the ES have any hidden quick menu for this?
I have only had my ES three weeks and have not delved into all the controls. I can say from my limited use that you first want to find the screen that pairs the left and right temperature controls together. Then set the climate control to auto. With that setting made, the mechanical switch for the temp control is right there in reach can be changed by feel while driving. Raising the temp will shut off the A/C and lowering the temp will turn on the A/C. Once you have a comfortable temp, leave the controls alone.
If you want to drive around with the windows open, you will want to explore the climate controls farther.
For me, I set my comfort temp at 72. To quickly turn ON the AC, press Auto. Done
To turn OFF the AC, select Menu>Climate>press chevron symbol/button>highlight and press AC (Ugh!). I have not found a quick way to turn off yet.
I know this answer. On my ES 2022 - press the far right button that has recirculate - auto - outside air twice so that 2 green lights are on (AC is running).
To turn off, press that button once so only the bottom light is one (outside air) is lit. Works every time for me. So much easier than going through Menu.
I hope I described the procedure well enough so you understand.
BJ
BJ
BJ
BJ
And that concludes my learning process for the 2021 350 ES I bought new 3.5 years ago.
Now that I’ve finally learned all the technology in this car (or at least all that I’m aware of and am interested in using) we’re within a calendar year of the new Gen 8 model and I’ll have to start all over again on the new model! Ugh!
I wish the technocrats would simply leave well enough alone!
Denzlex (08-03-24)
Thank you!
I’ve never used my screen to turn my AC on or off. I just use the physical buttons. AUTO to turn on, and OFF to turn off. The only reason I’ve ever gone into menus is to re-sync the left and right zones after my wife adjusts the passenger side to her liking. Once the AC is on in the climate menu, leave it. There’s never a need to turn it off. It’s basically on standby. AUTO and OFF is all that’s needed.
The following 2 users liked this post by Denzlex:
bullnobull (08-03-24),
Jersey5974 (08-05-24)
I tried pressing the air recirculation button trick and yes it works. I, however don't like to recirculate the air in my car. Prefer fresh air always, even if it makes the HVAC work a bit harder.
So I found another option which is a bit better than having to go through all the main screen menu options to acces the AC control. If you split the screen so that there is a main screen and a slightly smaller secondary screen on the right you can actually access the AC button by using only two touches. I always use this split screen setup. With this, on the secondary screen you can select four sub menus. One of them is for climate control, Selecting that menu gives immediate access to an AC on/off virtual button.
I think thats going to be my go to option now.
Voice command works
"hey Lexus Turn AC OFF"
Myshkyn (08-04-24)
Using the OFF button turns off the AC as well as the blower fan. I prefer to have the bower fan in my car running all the time, even at very low speeds. This keeps the air relatively fresher. I also like the "AUTO" fan blower feature, I find the system regulates fan blower speed very well.
