Finally did it changed from single to triple beam headlights
#31
I'm assuming the turn signal and side marker lights (now LED based and contained within the sealed triple beam headlight assembly) are correctly functioning.
That leaves the the functioning of the triple beam headlight assembly's interior fan (a feature that the Bi-LED headlight assembly doesn't have). I'm not sure how you might verify the interior fan is functioning at all or correctly (TechStream ??), but do you know if the fan is operating correctly with your Bi-LED to triple beam headlight modification?
also i just watches a youtube video of disassembly of a 2020 camry base headlight which is almost the same configuration as the Lexus single beam just flipped and it also had a fan inside.
#32
is350
RX - 5th Gen (2023-present)
94
07-19-24 07:26 AM
