ES - 7th Gen (2019-present) Discussion topics related to 2019+ ES models
Garage Door Opener
Old 08-30-24, 12:04 PM
  #31
grp52
grp52's Avatar
Originally Posted by NoiseFree
I'm back to square one.
I left off with Remote I working twice (2) in a row last night.
Today I tested as follows:
Remote I:
Yes (1)
No (9)
Remote II:
No (9)
Assuming you've done the check for signal interference, I think we're down to something's flaky with one or both of the opener's electronics boards. Unless you're knowledgeable of and skilled at PCB board component level inspection and repair, replacement of the PCB board handling the remote functionality would be the next thing to try assuming you can even find a new replacement PCB for your 25 year old opener.
Might be time to consider replacing your opener with a new one.
If you do go for a replacement, remember your ES's Homelink is capable of two way communication with compatible openers to show garage door opening and closing status on indicator lights in the rear view mirror (See page 299 of the 2024 LEXUS ES300H OWNER'S MANUAL USA AND CANADA ONLY.)
Some garage door openers available now have bells and whistles that weren't available 25 or so years ago when you bought you're present garage door opener. Some have interference free LED lights built in, myQ with Wi-Fi connectivity so you can check the garage door open/close status as well as open and close it from anywhere you have internet access, and if you add a wireless keypad remote temporary PIN codes to enable "in garage" package delivery from delivery services that support that which can thwart any neighborhood porch pirate package thieves you may have.
Old 08-30-24, 01:51 PM
  #32
NoiseFree
NoiseFree's Avatar
Thanks I bit the bullet and have ordered a Chamberlain replacement opener.
Old 08-31-24, 08:12 PM
  #33
hotwings
hotwings's Avatar
When my trusty 1994 opener's receiver failed I fixed it with this
Receiver Receiver
It simply wires in parallel to the existing wired switches and externally replaces the old receiver.
Old 08-31-24, 08:33 PM
  #34
NoiseFree
NoiseFree's Avatar
https://www.amazon.com/LiftMaster-85...A1S3PMG7RY70QV
It looks cool. How does it connect to your existing door opener and talk to it?
Old 08-31-24, 09:37 PM
  #35
grp52
grp52's Avatar
The LiftMaster 850LM Instruction Sheet - English, French, Spanish (small pdf download) shows how to wire it into your opener's wired control wiring connection.
Programming a remote to the LiftMaster 850LM is pretty similar to programming any Chamberlain Group Homelink capable opening device except there's thee learn buttons - one learn button for each of the three remote channels the LiftMaster 850LM supports.
You can wire it up so that each channel controls a different opener device. Or, if you need to support a lot of remotes (think gated entry into apartment complexes or gated employee parking areas) you can wire it up for all three channels controlling just one opener device.
Once you've got the LiftMaster 850LM wired into your opener device(s) and remotes programmed into the channel(s) used for remote controlling your device(s), it works no different than you're used to with your opener (when your remotes were reliably working).
NoiseFree (08-31-24)
cjinthesky
03-14-20 01:05 PM
stevei
RX - 1st Gen (1999-2003)
03-01-10 08:41 AM
dania
12-27-08 08:16 PM
Peteyoung
GX - 1st Gen (2003-2009)
09-26-07 11:29 AM
enginyr
11-21-01 10:55 AM
Quick Reply: Garage Door Opener
