All-new 2019 Lexus ES to debut at Beijing Motorshow
#706
It seems as if Toyota/Lexus is embarrassed by their 2.0L turbo....
If the GS is really to be discontinued, the new ES, though it does look nice, certainly is not set apart from the Camry. Oh except for you can get the Camry hybrid with a Li-Ion battery pack and not the ES. And while I'm sure that there is some financial/marketing reason to all of that, if I were a potential Lexus buyer, that wouldn't make me feel like I'm spending the money on the best of the best. Because it isn't.
#707
#708
#709
I would have thought that the ES would be a prime candidate for the 2.0L. They don't offer the IS or the GS with AWD and the turbo. Oh and Lexus has re-named their '200t' models '300'. It's like they're trying to hide this motor.
....that being said, I've never drive any Lexus with the new turbo engine. Could be rough and inefficient for all I know.
#710
drives cars
Yes. Poorly thought out remote touch and no way to turn off the AC in easy way. Also, their Lexus dealer does not allow them to take the Lexus to the service person on the other side of the building at Toyota despite letting them know know they will pay the Lexus service rate.
https://drivers.lexus.com/t3Portal/d...f/OM33C68U.pdf (see page 368)
#711
What? There's an "OFF" button... Are they in a current-gen ES?
#712
#713
#714
Yes, my Lacrosse is the same way. It's one of my few irks with the car. You can't combine or re-route the airflow from dash/defrost/floor vents, either, without going into the video screen....you could on my older Verano.
#715
I see the new ES also doesn't have an AC button. It's fine with me. My IS had it and I never used it even once, but I certainly recognize not everyone feels that way. I never saw a need to keep the climate control running but turn off the AC compressor. I just set it and forget it.
#716
#717
I don't have any issue with it being on as needed. I believe having it "ON" only means it's available if the system deems it helpful. It won't actually be running the entire time. In my climate, it's very helpful in the winter, when it's so damp, for defogging the windows. It'll vary with climate and preferences, but like I said, I had it and never used it once.
#718
I believe the compressor' s function is linked with the Outside temperature sensor and cabin temperature setting. So the car only enables the compressor if needed, otherwise its disabled. So i don't mind not having a dedicated A/C button, it has not given me a problem so far.
#719
I prefer when there is a dedicated AC button like on the IS. But Lexus's reasoning to hiding it/ not adding a button is mostly because by leaving it 'On' it is a dehumidifier like JDR76 mentioned. It can reduce fogginess in the windshield, and less off and on reduces the change of mildew growing in the vent system. It's great on the hybrids because it doesn't have to use any gas and can run on electricity from the hybrid system. So even with AC 'ON' you can set your temperature to 85 degrees and it will be super hot or 65 degrees and it will be super cold. It's not much different than your thermostat at home. Just set the temperature to what you feel is comfortable.
#720
It is important that the A/C compressor be run occasionally during the off-season...maybe five or ten minutes a week. That, of course, is to keep the belt-driven compressor's bearings, pulley, and other moving parts lubed so that they don't dry out and corrode. Even with compressors run by an electric motor, it is also important (though somewhat less-so) to run them during the off-season. You don't have to put up with an icy blast from the vents, though......all modern A/C units allow you to mix as much heat in with the airflow as you want. just by turning up the heat-****. Also, most modern defrost systems automatically turn on the compressor in the defrost mode, to provide a source of dry air...that's why the air sometimes comes out cold and chills the windshield down unless you add heat.
Here's a link to that subject, and you may also find it mentioned in the Owners' Manual of some vehicles.
https://www.autorepairshopsanjose.co...car-ac-winter/.
