Oil changes - every 10,000 miles? Even the first??
#211
For me, expecting to keep the car long term, a < $100 investment on additional oil change is a well worth insurance & peace of mind on a $57k+ car.
Based on my results as of February (6mo into ownership) and only 2,694 miles, If I hadn't made the changes, I would have the following concentration of metals on my engine oil:
- Aluminum: 9 + 3 = 12 (universal avg. 5) *The most common source of aluminum in engines is from the piston
- Copper: 64 + 16 = 80 (universal avg. 4) *Copper comes from plain bearings, bushes, thrust washers, worm gears.... it can be a little disturbing to see several hundred ppm of copper in a
sample. - Iron: 14 + 8 = 22 (universal avg. 9) *In engines, the cylinder liners and the crankshaft are the major wearing components along with timing gears, shafts and valves.
- Silicon: 224 + 80 = 304 (universal avg. 27) *Silicon carbide is sometimes used in the construction of pistons to reduce their coefficient of expansion. Greases contain silicon (particularly bentonite greases) and assembly compounds often contain silicone based chemicals that easily leach into the oil.
*Source: Technical Bulletin, issue 47, WHERE DOES ALL THAT METAL COME FROM? by John S. Evans, B.Sc.
#212
#213
#215
I've been meaning to show you guys this video, Lake Speed Jr. I know I know just another video with a guy saying something. However this guy is extremely respected in the top top engine builders as well as worked for big OEMs. he is a certified oil tribologist and eats, sleeps, and breathes oil science. He only speaks when backed with data. Long story short? Do your break in oil changes less than 1k miles, and do 5k changes after that -- exactly what ive been shouting to people for over 15 years on forums of various makes.
He does a lot of interesting videos as well including on the 0w-8 topic.
Aligns with what car care nut says too.
But yeah for you guys' oil changes.
https://www.youtube.com/watch?v=_6nWCQ_70J0
#216
This is on my wife new NX350h.
1K miles 1st oil change on my dime, cost me $40 labor with my long time mechanic.
5K miles or every 6 months after, whichever comes first.
Did the same routine on my wife's old 08 RX350 (now my teenagers' SUV) 165K miles as of today and my 17 ES350.
Will continue this routine no matter what Lexus recommends.
#217
Two questions for the oil change experts on CL: I'm approaching 500 miles on my 2024 ES 300h, and plan to change the "break-in" oil soon. I put "break-in" in quotes because I have yet to find any information as to whether or not Lexus/Toyota use break-in oil at the factory. Most people on the internet claim "no," but don't cite any references (for all I know...they're guessing). A true break-in oil is not synthetic and does not have friction-modifier additives to allow controlled wear between the rings and cylinder wall. If Lexus doesn't use break-in oil, I have no qualms about changing it early and often before the first free change at 10K. First question: Anybody know for sure about "break-in" oil in new Toyota/Lexus vehicles? Is it formulated different from the oil they sell you at the dealers? If it is different, I will leave it in longer for the break-in benefits.
I'm also looking for information on alternative oil filters. The OEM specified filter, 90915-YZZN1, is super small. I'm wondering if there is a Toyota filter that has the same specifications, but is longer? Too, since this will be my first oil change, I'm not sure if a longer filter would even fit. I found several similar Toyota filters that might work. The 90915-YZZD1 and 90915-YZZF1 both look longer, but I'm not sure their other spec's match up to the "N1." Second question: Has anybody experimented with larger filters, and if so, do you have any recommendations?
My general plan is to change the oil at 500-700 miles, then at 5K miles, and then let the dealer do their free 10K oil change.
xmlstarks (05-22-24)
#218
If you plan to keep the car long term, this looks like a good plan. Specially for the first year. After that. unless you drive under the manual "severe/special conditions" you can keep the 10k interval IMHO.
#219
The oil that comes in our cars is the same oil you’ll get at the dealership. OW-20 of any random major brand. Mobil, Valvoline, whatever…. This was confirmed by The Car Care Nut in at least one of his videos. My service dept. told me the same thing.
scubapr (05-22-24)
#220
Yep. Changing your oil at good intervals is massively more important than brand. Always do the break-in change 500-800 miles, then 5k thereafter. done.
#221
I'm changing the oil filter to the High Performance - Premium Guard Extended Life for my 2023 Lexus ES300h - Oil Filter #PG4476EX and motor oil to the Idemitsu 0W-16 IFG 5 fully synthetic oil. This motor oil is from a Japanese company that refines motor oil for Japanese vehicles. Recommended by my Independent Lexus Mechanic, he owns his service shop.
I tried to get the new Idemitsu IFG 7 motor oil, which is specifically made for hybrid vehicles; however, I could not find it anywhere in the United States, not yet. If anyone knows where to obtain this oil in the United States, please let me know.
https://highflow.com/products/lexus-...-2023-pg4476ex
IFG 7 0W-16
IFG 7 raises the bar as our new top-of-the-line flagship oil with Septet Guard™ – seven ultra-protective advantages to optimally complement high-precision engines for the ultimate in fuel efficiency, power, performance, and protection with minimal friction. IFG 7 0W-16 SP/GF-6B is a fully synthetic, ultra-low viscosity formulation for hybrid and fuel-efficient gasoline vehicles with robust additive technology for OEM-specific extended drain intervals and emission system protection.
scubapr (05-22-24)
#222
BTW...Your "Premium Guard Extended Life" filter was new to me so I did a little research. It seems well made, but didn't see any performance reviews online. It's about the same cost as the Fram Ultra Synthetic, which is what I plan to use after warranty. I like the Amsoil filter better, but it is $20! Unfortunately, Purolator doesn't make their "Boss" filter for the 300h, or I would go with it regardless of cost!
#223
Yes I bought the Idemitsu IFG 5 0W-16 from Amazon, the 5-quart container for $39.95 plus tax. It's not the same but still has 5 additives, thus the 5 designation. About PGI
Premium Guard Inc. (PGI) specializes in designing, manufacturing, and distributing products for automotive, diesel, power sports, and specialty filter markets. Headquartered in New York City with a main distribution center in Memphis TN, Premium Guard Inc. is keenly focused on providing customers with industry-leading service, complete solutions, best-in-class-quality products, and leading application coverage at compelling prices.
PGI also offers a platform for a turnkey private label solution, including product and packaging design, engineering, quality control, supply chain management, distribution, logistics, marketing, and professional field support.
Wilson2000 (05-23-24)
#224
The factory oil in these engines is the same TGMO 0W16 that you can find at the dealership. It is called break-in oil because it happens to be inside the engine while break-in period.
#225
Just saw this. I know some people don't like him. But to me, he appears to be an honest mechanic trying to help others by transferring his knowledge and experience; even if he make profits from those videos.
I hate when people say they don't care because they don't keep the car for long; then this happens to the next owner.
Those last 5min (from 41:25) should be a sticky for people asking about this topic.
Wilson2000 (06-10-24)
