Checklist for picking up your ES - 7th Gen
Stealing an idea from a Subaru forum, let's make a list of things a new owner should check when picking up their ES
Please post your thoughts and I will add them to the list
Note: This a work in progress, I'll update this post to add things as needed.
Here is a list of things to check when picking up your new ES
Business Office
Take a photo of the window sticker before you head in for reference when completing the paperwork
Does the VIN on the paperwork match the VIN on the car?
Are all the discounts you were offered reflected in the paperwork?
Does the final price match what you expect?
If you added anything not on the window sticker be sure to get a "We owe" sheet listing them
Take the time to READ what they give you and double check their math.
Examining the car
Use your copy of the window sticker (or the real thing) to check/test all the options are present and functional.
With the tires cold, use the Tire Pressure display in the cabin to check the pressure against the recommended PSI found on the drivers door sill.
Test the seat adjustments, lumbar support and extender if you have one.
Set a memory position, move the seat, steering wheel and mirrors see if they all return their proper place
Bring a USB cable for your phone, test all USB ports. Bonus points if you bring a 12v USB adapter and try that as well
Try the Qi pad if your phone and ES has one.
Close inspection for dings/scratches on all surfaces inside and out
Check the leather wrap on the steering wheel is tight and smooth
Check the HUD is level and adjust the height as needed.
Check that all shipping/protective coverings are removed.
Check the rubber seals on all windows to make sure it's smooth and not doubled over.
The whirring "space ship" noise the car makes when backing up is normal. It's a "safety" feature mandated by the US Government.
Business Office
Examining the car
After driving around for three weeks I just noticed a bit of plastic wrap still stuck the the passenger side A-pillar. So checking for that has been added to the list.
Also there was a post about checking the seals outside of the windows to make sure it's not doubled over.
AutoxMiata
ES - 7th Gen (2019-present)
15
01-21-22 11:10 PM
Nigel-JDMParts
Club Lexus Vendor Marketplace
06-23-15 07:53 PM
