The road not taken.
We had a long extended and varied search before we finally purchased the ES 300h. We really wanted a Hybrid or PHEV. One car we came very close to purchasing as in actually made an offer on before having second thoughts was the Pacifica PHEV. It was a wonderful car to test drive but two different vans at two different dealers had battery problems on our test drive.
Today I was checking this forum where I see active threads on:
Android V Apple
Wind noise
Illuminated Trunk sills.
Over on the Pacifica fourm I see active threads:
2018 Pacifica Hybrid almost caught fire after latest recall fix
All owners !!! Pacifica hybrid cought on fire - escaped from the car
Battery dies on Pacifica Hybrid - Rolls out of driveway into street!
Dead battery adventures
Let me count the ways..... this car sucks
Feel like I dodged a bullet on that one.
Android V Apple
Wind noise
As somebody who owns a Pacifica and posts on that board, you made the right choice lol. You should read the non hybrid forum! Sliding doors falling off vans and Chrysler refusing to cover it, numerous infotainment failures, gas Pacificas dying in the middle of intersections because of a fault in their engine start stop system. Mine has been in the shop 3 times for frozen nav screens, and they replaced the whole unit the last time and it still freezes. Rear theatre doesn't work half the time, The vacuum hasn't worked in a year, now one of the sliding doors is grinding (afraid it will fall off) and the automatic parallel parking runs into curbs and other cars.
Its amazing to me the number of problems there, and how they all just think this is how it should be. In one thread a guy actually said "it just used to be that you bought a car and it was many years before it started having major problems". No! These cars are just garbage!
A Lexus/Toyota might not always be the fanciest car you can buy, but its a great combination of fancy, quality and dependability.
The following 2 users liked this post by SW17LS:
signdetres (02-12-19),
Steve300h (02-11-19)
I had a '15 and '17 Jeep Grand Cherokee Summit which both gave me problems from the outset. With the '17, the air suspension failed in cold weather. Imagine driving 300 miles on the interstate riding on bump stops! The Jeep forum makes clear that FCA is well-aware of the problems with Quadra-Lift. For me, the dealership could not reproduce the problem so I was SOL.
The two best things about the Summit were the seats/ride and the awesome Harman-Kardon sound system.
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1333/jd_power_vds_2019_promo_a94d34ba82e5a7570f2283ac5b8c618eb0186699_108aecb0867ea4669dc82812444133e683f3cee6.jpg)
Think this chart will explain a lot. Lexus has been #1 for an amazing eight years in a row.
Isn't Pacifica a minivan? Trying to understand cross-shopping with the ES in that case.
If I've got $45 k to spend, why wouldn't I consider everything in that price range, assuming of course the functionality of the different vehicles meets your needs as you define them?
IMO, the incredible slicing and dicing into classes of vehicles today is strictly for the benefit of the manufactures, not the consumer.
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/1527x1755/jd_vs_cr_2d9337d626620e009e5348d1332ca2a100a9515c.png)
Steve - nice work on the arrows and good choice to go for a Lexus over a Chrysler no matter what you're shopping for
Did you read Car and Driver's long term test of the Pacifica PHEV? They're about half way through now. Here are some excerpts:
From the 10k mile update:
And the 20k update:
https://www.caranddriver.com/reviews...d-reliability/
WHAT WENT WRONG: The Pacifica hybrid rolled in to the dealership for its recommended 10,000-mile service without giving us a hint of trouble. Along with an oil change, tire rotation, and multipoint inspection that cost $101, the dealership performed a recall service to update the powertrain control module, battery-pack control module, and power-inverter module. While we didn't experience any malfunctions, FCA issued the recall to prevent a cruise-control glitch that could potentially cause the system to maintain speed or accelerate unless the driver shifts into neutral or applies the brakes.
Barely 500 miles later, on a trip to Grand Rapids (about 140 miles west of our Ann Arbor office), the minivan rattled on startup and went into limp-home mode. Photo assistant Charley Ladd was behind the wheel and nursed it to the closest dealership, where the technicians determined that the high-voltage battery needed to be replaced (!), a job that was covered under warranty. However, after installation, the battery wouldn't charge. A field engineer was dispatched to diagnose the issue and found that the battery control unit had the wrong software installed. Reprogramming it fixed the charging problem, but the dealer was not able to re-create the rattle on startup
WHAT WENT WRONG: Not long after we experienced serious issues with the Pacifica's hybrid system, which required replacing the entire battery pack under warranty and later updating its software because it wasn't charging, a warning light appeared, along with a "Service Hybrid Electric System" message. We eventually discovered that this was triggered by the coolant-level sensor, and the dealership confirmed that the battery coolant was one pint low. The technician refilled the coolant but was unable to diagnose the issue because no leaks were found. A couple thousand miles later, the warning light went off again, and again the battery coolant was low. The dealership drained and refilled the coolant reservoir but still couldn't find any leaks. While we haven't had any problems with the coolant level since then, the issue remains a mystery.
