What mileage are you getting on your ES 300H?
Today, I got 48.7 mpg on my 2019 ES 300H on a 12 mile trip. Would love to see a 50 plus when the weather gets warmer. Love this car! Just curious, what are the rest of you getting? What is the most you've gotten?
Any results, whether from the car's computer or actually calculated, based on a 12 mile trip are likely to be quite inaccurate. Unless a fill-up requires a minimum of 5 or 6 gallons of gasoline, I would not be confident at all in the accuracy of the results. The most accurate results will be achieved when the fill-up is over half of the tank's capacity and when the mpg is manually calculated.
Arabh (01-23-20)
I haven't gotten my ES yet but I remember there being 2 estimates. One for the current trip and one for total since last reset. I've noticed on my Camry (a similar setup) that the estimate since last reset is usually within 2 miles of actual (which I always calculate when I fill up).
I've had several new Lexus' over the past few years, and NONE of them were within 2 to 3 MPG in accuracy. Why do you suppose they don't do this correctly? They have to measure the actual fuel delivered through the fuel system (the MAF has to determine the fuel/air mixture with a high level of accuracy) itself so they can give us a semi accurate Miles to Empty, which seems relatively accurate when you consider the "reserve" they ignore when calculating it, so why can't they get the MPG closer? Maybe I don't know as much as I think, but this just seems odd
That kind of variation has never been my experience. The last three Lexus’ vehicles I have owned are typically showing dash mileage that is within two miles of the calculated mileage. There have also been rare times that it is nearly spot on. I would argue that the dash mileage averages about 1.8 MPG higher than actual. This is truly another one of those first world problems isn’t it?
Also, my average miles/tank is 513 miles, with an average fill up of 12.3 gallons.
Needless to say, I’m quite pleased!
My MPG doesn't seem to be as good as it should be. I'm currently on my second tank of gas so it might take some time to get a real idea but so far I'm a little underwhelmed.
For my first tank I got just over 37 but over the course of the first few days I spent several hours just sitting in the car with the car on so the car would occasionally turn on the gas engine which burn gas but didn't go anywhere so I expected somewhat lower mileage.
On my second tank so far I'm at 352 miles on the tank and an estimated 130 miles until empty (not counting the reserve). The estimated MPG calculated by the car is 40.8. Based on my experience with the accuracy of the estimate on my old 2011 Camry it's probably about 40 MPG. That's not as good as the 44 MPG that is stated and the even better MPG others seem to be getting. I haven't been heavy on the gas and I've been keeping it in the Eco drive mode with about 90% freeway driving.
My first tank was 586 miles and it took 12.4 gallons to fill back up, resulting in 47 mpg. The car displayed 45 mpg.
Half of those miles were in a one day highway trip. The rest were commuting for work (mostly highway). I typically leave it in eco mode on the highway and switch to normal mode in stop and go traffic or merging. I do tend to hypermile a little since I had a Honda Fit 10 years ago. Not too excessive with the hypermiling....really just trying to keep accelerating and deceleration as smooth as possible. I leave AC and cooled seats all on auto but use eco AC mode.
The EPA estimate for freeway is 45 mpg. I know that's usually high compared to real world but I was at least hoping for a solid 43 mpg.
Mileage isn't bad but certainly not meeting even low expectations.
