Dynamic Cruise Control Notification
When using dynamic radar cruise control a notification pops up on the multi info display every time the radar detects or stops detecting a car as well as other conditions that I haven't actually figured out. Sometimes it just seems random.
I've looked at all the settings I could find to turn it off but I can't find anything. Is there really no way to turn it off? It's extremely annoying and comes up constantly.
You have the ability to turn off "Pop-Up Display" in the "Meter Control" section of the "Settings Display". It says "Warning or suggestion/advice pop-up displays are also displayed in certain situations", but I can't find exactly what they are. You can try turning them off and see if it helps.
See page 76 in the owners manual.
You can also hit the back button which will take you back to the screen you started on - MPG etc.
If you select that mode, then turn cruise off, then on, does it return to "vehicle to vehicle" mode or remain in conventional cruise?
It remains in conventional cruise control until you either turn off cruise control or you switch off the car and back on.
15 seconds seems excessive although ive not tried it in the ES. In our RX, you only have to hold it for roughly 3 seconds to select conventional with no radar.
When in adaptive, does it put the car into coast or apply the brakes?
It mostly uses the brakes, sometimes, when going downhill, the car can shift a gear down and use the engine to slow it down.
LeeSoFL (05-27-19)
If I understand your question, it seems that the notification that pops up just alerts you that the radar has slowed the car below your set point speed due to the proximity of the car ahead or that you have cleared the car ahead and it is resuming your set speed. I know of no way to disable the notification other than not use the dynamic portion of the cruise control.
That cruise control notification pop up is so annoying.
Gr8Car4Me (05-27-19)
I sorta feel you look like a novice driver when your brake lights keep coming on when driving 70 on a highway.
When using adaptive cruise on highway situations I have found myself wondering if the car is applying the brakes or just backing off the throttle and letting wind friction slow the car. The designers make it a big point to tell you if the radar detects a car ahead or not, but no indication on brake activity that I can tell unless the braking is enough to be obvious. Is there some indication about brake application I am missing? I do wonder if/when I am signaling to the cars following me.
I'm pretty sure it uses the brakes, and it's NOT always very smooth. It doesn't seem to coast much. Either accelerating, maintaining speed, or braking, and not much in between. It must be because it doesn't look very far in front of the car. It does seem to either be getting better, though. Either that or I'm getting more used to the lack of subtlety. I wonder if it learns.
This would be a lot more useful on an interstate, with a more constant flow of traffic. I like to play with it in traffic, where it slows and starts on it's own. The only intervention needed is after it comes to a complete stop. I also occasionally use cruise to help avoid speeding in moderate traffic on surface streets. It gets a little dicey sometimes and you have to pay attention. I know I'm not using it in the conditions it's designed for, but it's kind of fun and I appreciate the technology. From a more practical viewpoint, it really is a compromise. and I'm not sure how it could be improved.
Moogy
05-07-18 01:08 AM
kymbakitty
RC - 1st Gen (2015-present)
06-23-16 07:20 AM
J3ffrey
12-12-15 07:31 AM
orthrwi
08-01-10 06:35 AM
