Luxury vs. Ultra Luxury
There are no performance dampers except the lateral ones. I do believe I recall reading that they were added to the Luxury trim level. If memory serves, the rear-door sunshades and laminated (sound-reducing) front door window glass are the only remaining features you can't get on anything but a UL. What makes that a bit less significant is that I just don't think they're building a lot of Luxurys this year.
https://www.lexus.com/content/dam/le...S-Brochure.pdf
Lateral performance dampers can be added to Premium and Luxury. You can buy them from the dealer and they can be bolted, plug and play.
I don’t think anybody can see the difference between on the car with lateral performance dampers and without them.
Rear door sunshades are available only on UL but the front door eliminated windows are available on Luxury.
As others have mentioned, the rear sun door sun shades are also unique to the UL models, as is the Semi-Analine seating material. I believe the Panoramic sunroof is only available on the UL model as well. So yes, more than just the performance dampers.
You can have the Panoramic sunroof even on Premium.
So the exclusive options for the UL model are:
Side sunshades;
Dampers;
Semi-aniline leather;
Illuminated door plates;
Dampers and illuminated door plates can be added since they are plug and play.
Dampers are mounted to the fixed frame and they help reduce some high frequency vibrations. That’s all.
Side sunshades;
Dampers;
The brochure may state that however the spec sheet for my vehicle has Lateral-performance dampers listed as equipment on the car. Believe what you want.
Side sunshades;
Dampers;
Side sunshades;
Dampers;
I have a fully loaded Luxury ES350 that has the semi-online leather with the cushion extender and the lateral-performance dampers.
The illuminated door sills or illuminated trunk sills just seem to be added during production not really part of the UL package.
Regardless of whether you can get to UL level by adding all options to L, it makes sense to just buy UL instead of the other route. Price will be a little less and better resale because it’s a higher trim than lux
wmoor004 (02-13-22)
Honestly, I'm not sure why the UL trim exists at this point, except just to get people like me to pay more. It not only has nearly nothing unique, its standard equipment list LACKS things like Mark Levinson that many or most lower-trim examples are delivered with, and it isn't even badged anywhere. It's one of the most pointless 'trim levels" i can ever remember.
