Hiding your USB drive and cables
#31
Nice ideas, guys. How did you guys remove the USB door? I tried trugging at it but no dice. Maybe i didn't look close enough. This is another area of the car i want to address. hate driving around with the cupholder door open all the time just so i can play music and use ACP. It should've been in side the glove box
the wire def needs to be hidden though. none of that stuff where the wire is taped to the outside lol. wth.
#32
^Nevermind went out to my car and checked. It has a different USB port than you guys. the hinge on my '21 is on top. door does not appear to be removable. i'll try later with some tools but seems i'll have to disassemble the whole tray to remove the door.
#33
kalel2127 (04-14-21)
#34
First, I agree the center console should still have a USB port that works with Android Auto and CarPlay. I find it remarkable that they deleted this feature from this generation of ES. Secondly, the notion of leaving the cupholder door open all the time is amusing. Since the cupholder door covers the cupholder, my door is pretty much always open because there is a cup (bottle actually) in it. My wife almost always brings a drink with her. I can honestly say I don't understand all the statements about how terrible it is for this cupholder to be left open. Guess what, the one on the driver's side is routinely left open as well because there is also a driver frequently in the car, sometimes with a drink ... at least while it is in motion.
But still having the USB port there in the cupholder is asking to take a bath in a liquids some day. i already came close one time.
#35
1Priest (06-27-21)
Mattinnv (05-16-21)
#41
#42
Also, if that said drink happens to splash into the trackpad causing it to stick or get "crunchy" when using, the service dept. might charge for "cleaning" it. I actually had this happen but it wasn't due to a drink and they did fix it under warranty when they were already working on the squeaky console. This was on my 19' Lux. In the past I've used a Q-tip and some rubbing alcohol to help loosen it up by going around the perimeter of the trackpad or buttons. That solution worked for me. I'm not specifying that it should be done. Only that I tried it and it worked. YMMV
#43
I explained it in my post here in the other thread. There's no clean way of doing it that is reversible. I took it to my dealership and took the technician 5 mins to remove the whole USB module and remove the lid and put the module back in place. But to remove the lid, only way was to break it off. Result look clean now! I'm not worried about breaking it off. That whole USB module is not that expensive to replace if it came to that but I'm supper happy now!
#44
There was no disassembly of anything involved. That USB port section pops off with a little pry tool. The plan wasn't to break it but he said there's no other way to remove it and I'm fine with it. I think if I cut it or broke it myself, it would have left some small pieces near the hinge that may not have looked as clean as now.
#45
