Shhhh I shut off Eco!!
#31
#32
That is correct. Using the Eco mode is only going to result in better fuel efficiency when the transmission has to do lots of gear shifting, and, with highway driving, once the car reaches fairly steady cruising speeds, the transmission will remain mostly in the highest gear. In that situation, there will be virtually no difference in fuel economy regardless of whether you are using Eco, Normal, or Sport mode. Use of Eco mode, on the other hand, when driving in urban stop-and-go situations is where there is likely to be more significant improvements in fuel efficiency.
#33
I immediately go to Sport also. I only use ECO when I'm on a long trip and only once I've achieved cruising speed and engage the cruise control. Then I flip it over to ECO. Just returned from a trip from Tampa to Savannah and ran a nice 36MPG avg for the 650 mile round trip.
#36
landonm86 (04-13-22)
#38
I suspect it's slightly reducing the performance of the HVAC system in this case.
#40
That's good possibility. There is also a "Eco" mode for the HVAC that can be toggled on/off. I've never checked to see if turning the drive mode to Eco automatically toggles it.
There are multiple overdrives on the car too. The shift logic is probably tweaked such that the threshold conditions to drop into 8th gear are lowered and the car spends more time in it on the highway.
#41
