Help with previous Gen Wheels on 2019-20
Hello all,
I am looking to put a set of 2015-2016 Black Crafted line wheels on my current gen 2019 that currently has the noise reduction wheels. My question is do I need TPS sensors from the previous gen or the current gen. I want to make sure they work as lexus shows different part numbers. Any help will greatly be appreciated.
2016 Wheels
Wheel Size 18x7.5
Bolt Pattern 5-114.3
Offset 45mm
Tire size P225/45R18
2019 Wheels
Wheel Size 18x8
Offset 45mm
Tire size 235/45R18
2016 Wheels
Wheel Size 18x7.5
Offset 45mm
2019 Wheels
Wheel Size 18x8
Offset 45mm
Tire size 235/45R18
Hello all,
2016 Wheels
Wheel Size 18x7.5
Offset 45mm
2019 Wheels
Wheel Size 18x8
Offset 45mm
Tire size 235/45R18
2016 Wheels
Wheel Size 18x7.5
Offset 45mm
2019 Wheels
Wheel Size 18x8
Offset 45mm
Tire size 235/45R18
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/19es350_wheelcoat_d28a83f59c5a76ab21f15c081255028b95b2edf8.jpg)
Thanks for the reply, i actually already have the rims. Because of that i want to have 2 setups 1 for winter 1 for summer. So I have to buy new sensors, Im just trying to figure out if i need 2019 sensors or 2016. Because the sensors have to fit the 2016 wheels, yet still work with the 2019 car.
In that case I will say what I should have said in the first place: I don't know.
I like the crafted line wheels for sure though. I bet if you ask tire rack they will know. Tell them you are buying new tires for the wheels etc and ask about the tpms.
