USB to CARPLAY2AIR
USB to CARPLAY2AIR
Another first time Lexus Owner. I have never been a car person. all I needed a car to do was start up and let's go. Yes I would maintain what i had and kept them running and looking good. I was a Motorcycle Guy (no not a Harley)
so at age 56 I had a change of heart and Picked up one beautiful 2020 ES350 and love it.
The sounds system is OK for now. Here's what I need help with I purchased a CARPLAY 2 AIR a little slow to connect but it works great now I'm look for a way to connect to the USB and still close the lid of the cup cover. Is there a 90 degree usb cable short/ low enough that will allow the cover lid to close?
Thanks
Thanks
I've had my CarPlay2Air for about 6 months and have been looking for the same solution. The best I can figure is to go to a car audio plkace and have them remove the center console and run an extension line fro the front USB port to the center glove box and install a USB in there.
I haven't priced this out yet though. If you figure something out, Please post it here
Could you use this cable with a female to male adapter?
EDIT: I just realized after I posted this that it won't work because the cable that I posted with the right angle USB has an Apple plug on the other end.
Correct. It would probably have to be something like this.
https://www.amazon.com/Right-Angle-F.../dp/B00KFL4R8A
EDIT, wait, that wouldnt work either. You need cable option one with this:
Why not? What was the problem? Did it stick up too much or did it just not work?
No, the first one I mentioned won't work because it has an 8-pin lightening plug on the other end.
The 1st one you mentioned will work but maybe in conjuction with the 2nd one.
https://www.amazon.com/Cable-Matters...tronics&sr=1-3
FTBoomer (05-20-20)
