2020 ES 350 Transmission Shifting
#46
No the acceleration delays and jerking is not normal. I have a 2020 ES 350 and I just recently started to experience the jerking and a time delay when accelerating and decelerating. My car is currently at the dealer, for this issue. This is my third time taking it to the dealership within the past three months, due to this issue. They told me they fixed it before and that the system just needed to update and now they are trying to tell me it’s normal. I’m not buying it. There is clearly an issue with the acceleration that they do not won’t to properly address. I experienced this same issue with my 2010 Toyota Corolla, and had to have the transmission replaced. After the transmission was replaced the acceleration was smooth.
#47
Let us know what happens. I would be very interested in what your dealer says/does.
I did a little digging and apparently the 2021 model has a different computer part number. I don’t know about the software, but my SA at the dealer did mention that others have said the same as I have about noticing a substantial performance and drivability improvement over the 2019/2020 models in the 2021s after having one as a loaner.
LexFinally (10-29-21)
#48
I had a 2021 ES250 loaner with the 8 speed transmission and a 2020 RX with the 8 speed transmission. The drivability of them is far worse than the refined and smooth 6-speed transmission that I am accustomed to. I always have to keep them in SPORT mode to get any decent acceleration with these 8 speeds, especially with the ES250 which is grossly underpowered and has the wrong powertrain for this vehicle (which should be in a Camry not an ES) to begin with.
#49
Lexuss07 (10-31-21)
#50
My 2019 has the same 8 speed tranny. I complained about it early on after comparing it to the 6 speed in my 2013 ES. In my opinion the 8 speed doesn't compare favorably with the 6 speed. It is indeed jerky and I have also experienced the acceleration from a slow roll where the trans doesn't "know" which gear to select, lower or higher. I think the 6 speed is much smoother shifting and I couldn't always feel when it even changed gears. I would take the 6 speed over the 8 speed in a minute. This is a negative with the 7th. gen Lexus Executive Sedan IMO...
#51
For what it's worth, my 2021 was experiencing some hesitation on shifting up from a stop, especially climbing a hill. I switched to 91 octane fuel and everything went away. You and others may be skeptical. All I can say is it worked wonders in my low mileage original owner car. Try a tankful. You have nothing to lose. I use Sunoco.
SonOfABisc (02-28-24)
#52
22' ES350 F-Sport experiencing same symptoms as many others. Especially when cold and in ECO mode forget it, it's like a jittery roller coaster. When warm it always hunts gears and when stopping very aggressive downshifts that make you jolt forward. Dealer stated it is normal for the 8-Speed's. Has anyone changed fluid and see if it helps smoothen things out? Also saw a few responses about a TCU update but it looks like on earlier models?
#53
#55
#56
Rarely ever used sport mode but for about a year I used normal and when switched to eco it was about 2-3 MPG difference and just leave it there. Mine is hybrid and may not relate to non hybrid mode settings. I really like the AGC feature when in eco mode.
#57
Yeah I can't imagine SPORT in a hybrid? But I'll find out soon. My wife takes delivery later today on a 24 RX350h.
#58
My '24 ES350 sometimes downshifts abrubtly at a stop sign epecially when cold but I've been happy otherwise.
#59
overclock
ES - 5th Gen (2007-2012)
02-07-10 05:39 AM
