ES - 7th Gen (2019-present) Discussion topics related to 2019+ ES models
Wipers
Old 07-13-20, 11:31 AM
Mrslady
Mrslady's Avatar
Default Wipers
2020 ES has anyone tried folding back the windshield wiper to clean the window?
Old 07-13-20, 11:45 AM
mikemu30
mikemu30's Avatar
Received 2,542 Likes on 1,815 Posts
See page 159 of the manual to move the wipers into service position.
Old 07-13-20, 01:06 PM
bc6152
bc6152's Avatar
Received 1,300 Likes on 905 Posts
This was one of the first things that I noticed when I bought my 2019. On the previous gen - 6 - you could simply raise the wipers to the winter position and pull them forward to clean the windshield. Not on the gen 7 cars. You must push up the wiper stalk as if you're doing a one wipe within 55 seconds of turning the car off. Problem is, the windshield is usually dry and you can score the glass. Ask me, I did... After you push up the stalk and the wipers run over your dry windshield to the up position, you can then pull them out to clean the glass. This, IMO is one of the stupidest features that Lexus has included on the gen 7 cars. Otherwise you must first wet the windscreen with the washers, turn off the car, then push the stalk up within 55 seconds.
When I complained on the forum most of the other members thought I was a crybaby (LOL) and that it was very minor. It's not minor to me and I think it's very poor engineering and just stupid by Lexus....
kalel2127 (07-14-20)
Old 07-13-20, 02:49 PM
mikemu30
mikemu30's Avatar
Same on our 17 RX. Perhaps its an effort to keep them less visible when not in use. Remember back in the day when GM introduced "hidden wipers"?
Old 07-13-20, 03:58 PM
bc6152
bc6152's Avatar
But on my 2013 you could set the wipers below the hood line i.e. less visible, or above as desired. Above in the winter and below in the summer just by pushing up or down on the knuckle.
Anyway, this race was already run and it is what it is...
Old 07-13-20, 07:43 PM
DavidZ
DavidZ's Avatar
Are you saying that you followed the instructions properly and it scored your windshield? If so, wouldn't that be covered under warranty?
Old 07-14-20, 06:35 AM
mikemu30
mikemu30's Avatar
Here's a tip - try cleaning the blades with alcohol every month or so and watch how long they will last. I'm still on my original ES blades after purchasing the car in Dec-18 and they're still perfect.
Old 07-14-20, 10:07 AM
dklanecky1
dklanecky1's Avatar
Which brand works best , or are you referring to plain old rubbing alcohol?
Old 07-14-20, 10:08 AM
kalel2127
kalel2127's Avatar
Mine only lasted about 4 months before they started to leave streaks. I cleaned them with alcohol thinking it was just probably due to debris and no luck. I decided to upgrade to Rain X AdvantEdge and so far they are holding up.
Old 07-14-20, 10:53 AM
mikemu30
mikemu30's Avatar
That's all I've been using.
Old 07-14-20, 10:55 AM
mikemu30
mikemu30's Avatar
Are those a direct fit for the ES? I presume I'll eventually have to replace mine. I've used Trico replacements before with success.
Old 07-14-20, 11:03 AM
DavidZ
DavidZ's Avatar
This guy recommends silicon-based blades. He says they last much longer, but you should still clean them regularly with denatured alcohol..
Old 07-14-20, 11:58 AM
kalel2127
kalel2127's Avatar
Yes, only took about 5 minutes to swap the pair.
mikemu30 (07-14-20)
Old 07-14-20, 12:04 PM
bc6152
bc6152's Avatar
I've used Premium Rain-X on my 2013 and now on the 2019. Very good blades and fit perfectly. Takes 10 minutes to change both sides.They have blades for summer and winter. Sell for about $10.00 each at Walmart...
mikemu30 (07-14-20)
Old 07-14-20, 01:13 PM
DavidZ
DavidZ's Avatar
Did you really scratch your windshield? Did/will Lexus fix it for you under warranty?
Quick Reply: Wipers
