FSPORT conversion
#31
ok, removing the rear bumper will be the hardest part. Its easy once you locate the invisible screws.. there’s 2 of them on each side of the bumper under the rear wheel well. There’s a small hole and you can only feel it with your finger. I used a deep socket 10mm. Or you can use a philip screw drive. There’s also a screws by the tail light behind the plastic cover you’ll see it when you open the trunk.
picture time!!!
same with the front Bumper.. all the holes that you will need to cut are marked behind the bumper.. cut inside the Center box. DO NOT cut pass the top line because holes will be too big. And it will show above the diffuser. Cut slowly!
clips are on!!!
Finished product!!! 🤗 you will also need 2 plastic push clips to secure the 2 lower brackets. I’ll get the part number tomorrow.
picture time!!!
clips are on!!!
I kinda liked the TRD valance more then the F Sports. The Fins Stand out more. But they force you to buy the whole under part sadly.
#34
Haven’t been in a forum lately 😊 I forgot How to post pictures..
here is my es still on dealership lot Oct 11
1 week old 😄
behind the front bumper side garnish. Its clearly marked where to cut holes. The F-sport side garnish is a lot bigger than the standard version.
FJ cruiser Bumper clips
you need 6 in the front and 11 on the rear diffuser
get em here at amazon
Rexka 25pcs Front & Rear Spoiler Moulding Clip Compatible with Toyota Lexus 75392-35220 4Runner, Camry, Corolla, FJ Cruiser, Highlander, Prius, Prius Prime, Prius V, RAV4 https://www.amazon.com/dp/B07BHCXWV5...ing=UTF8&psc=1
clips installed on the ES holding the side F-sport side garnish
finished
I already finished the rear diffuser install. Will post pics later.
~JoE
1 week old 😄
finished
~JoE
#35
I just bought my 2019 ES 350 Base and love it. I too am looking for summer tires and wheels to be the 19" F Sports, with winter wheels being the stock 18". Glad there is no clearance issues. I also would like to put the F Sport rear valance on eventually, but don't know if it will fit properly on the base rear bumper. If you find out that it fits before me, let me know please through this post. Thanks!
#36
Eggroll96 (04-18-24)
#38
I definitely like the F Sport grill as I've had a total of three F Sport Lexuses in the past, but honestly looking at the pics a few post above with the standard "Waterfall" grill, I think it fits the character of the ES better and gives it a distinctive presence out on the road vs a (nice) but "typical" sporty/mesh grill design. the waterfall design I think is unique and there's no mistaking it. let me know what you think in the comments below and give this video a thumbs up or thumbs down
#40
#41
Trust me I get it. I was and am an F Sport fan when they came out with the spindle design and decided to purchase a 2015 F Sport, 2016 F Sport, and 2016 F sport for actual compact/agile or sporty cars. I don't mind it on the ES, but it's not like a must have for me since the ES is large FWD with large overhangs, the luxury aesthetic I think is more fitting.
#42
Question
Hi, RV, I have a 2020 ES 300h and also wanted to put the F sport grille. I need to replace my front bumper and grille because of little accident, so was thinking if the F sport bumper would fit on my base model I just buy the f sport front bumper and grille and wouldn’t have to customize anything. Do you know if the front bumper are compatible? Thanks
New member here! Just want to share my FSPORT bumper conversion on my base 2019 ES350 with 19" FSPORT rims.
No fabrication needed. If you guys are interested, I can answer any questions. Lemme know what you all think.
-RV
[/QUOTE]
-RV
[/QUOTE]
#43
Hi, RV, I have a 2020 ES 300h and also wanted to put the F sport grille. I need to replace my front bumper and grille because of little accident, so was thinking if the F sport bumper would fit on my base model I just buy the f sport front bumper and grille and wouldn’t have to customize anything. Do you know if the front bumper are compatible? Thanks...
You need to take some care in selecting the right F Sport bumper assembly to get the one that will match up to your ES 300h base model build configuration. If you ES has the Premium package with the Intuitive Parking Alert support sensor's in the front bumper you'll need to get the F Sport version that also supports the Intuitive Parking Alert support sensors. I think getting the towing eyelet access covers configuration matching up isn't quite as important. Getting a mismatch on that will just be either wrongly implying your ES has the towing eyelet feature when it doesn't have the feature or preventing using the towing eyelet feature by eliminating access to the attachment point.
#44
1 week old 😄
finished
~JoE
1 week old 😄
finished
~JoE
First of all, thank you for this!
Secondly, I heard from other grille conversions that you need to have the sensors recalibrated after removing/altering the bumper.
Did you need to do this? Does your stop-and-go cruise control and sensors still work fine?
(I have the 2019 ES350 Premium version)
