ES300h - disappointed with Mark Levinson subwoofer. Any fixes??
My new 2020 300h is just today a week old. I noticed a buzzing in the subwoofer almost immediately and returned to the dealer to get a fix. The technician suggested turning down the bass and volume. Heck - the Mark Levinson upgraded audio is one reason that I sprung the $1000+! He took me to some other new ES300's and I plugged in my memory stick with the hyper-bass songs that I like. Tech was correct. They buzzed on the new vehicles also.
So I searched Google and subscribed to this thread to find that there are numerous comments on repairing and/or replacing the rear subwoofer. I can play the songs on my home stereo w/o the buzz albeit with a 12" subwoofer. I also have a 2018 Lincoln that doesn't buzz, but the rest of the sound system isn't as good as the Mark Levinson.
So is there any way that I can upgrade the subwoofer on my Mark Levinson system? Or do I just need to live with the suggestions and reduce my bass/volume??
There's probably at least 300 posts on this subject going back to 2013. Some think the ML system is fabulous and some think it's poor. Some members have altered it and think it sounds better and most just leave it alone and enjoy the premium sound. There was a TSB recently issued for the BASE sound system where the amp was replaced. No changes are suggested for the ML audio system to my knowledge. Depending on how important this issue is to you, you could contact an audio specialist and see if it can be changed to your satisfaction.
Otherwise, to this point in time Lexus has ignored the many complaints and made no changes to the ML system as far as I am aware.
GOOD LUCK!![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
GOOD LUCK!
I pushed the ML system pretty hard before installing my aftermarket subs and never heard a buzz. My assumption is that the stock sub is being pushed to its limit (clipping) and that is why you hear a buzz. What type of hyper-bass songs are you playing? Also, I'm going to go out on a limb here and suggest you purchase an aftermarket system since you have a memory stick with hyper-bass songs.
![DJ](https://www.clublexus.com/forums/images/smilies/DJsmile.gif)
Well, I do like the sound of the ML premium system. But it seems strange that the default with all tones centered is the best setting. The default does provide good bass. It's only when I push the system to the right of center that I get the buzzing. FYI the memory stick that I use for my test is:
- Ace of Base "The Sign"
- Eric Clapton "Going Down Slow" (and others) from the album "Pilgrim"
I also suggest always using the highest quality source material when adjusting the system and of course for best sound quality. High resolution FLAC and other lossless files sound very good. I've also been pretty happy with Amazon Music HD using the highest quality versions they offer. Ace of Base "The Sign" happens to be one of them and sounds quite good on my system. MP3 audio files and SiriusXM are usually low quality and are not adequate to properly evaluate and voice the system, IMHO.
emas (10-28-20)
That said, your questioning on the audio source and audio source file are good ones. The 2019LEXUS ES 350 Navigation and Multimedia System Owner's Manual (presumable the 2020 ES 300h version is similar if not the same) is pretty specific as to audio file formats, sampling frequencies, bit rates, channel modes etc. that are supported. Even assuming there are no encoding errors in the digital audio source files on the [USB] memory stick you can still get playback errors/noise/problems if the source file isn't in an encoding and/or file format the system supports.
For USB payable media, the owner's manual also has the following:
When naming an MP3/WMA/AAC file, add an appropriate file extension (.mp3/.wma/.m4a).
This system plays back files with.mp3/.wma/.m4a file exten- sions as MP3/WMA/AAC files respectively. To prevent noise and playback errors, use the appropri- ate file extension.
*2: Sound source of 48kHz or more is down-converted to 48kHz/24bit.
I just listened to The Sign by Ace of Base on Amazon HD with my iPhone and Carplay. I turned the volume up to 46 and cranked the bass all the way to the right. I didn't hear any buzzing, but I could feel my chest vibrating with the bass notes.
Your problem may be something as simple as a loose screw. Or even something sitting on your car seat that's resonating. Look for the simple stuff first.
Originally Posted by DavidZ;[url=[url
tel:10921510]10921510]I[/url] just listened to The Sign by Ace of Base on Amazon HD with my iPhone and Carplay. I turned the volume up to 46 and cranked the bass all the way to the right. I didn't hear any buzzing, but I could feel my chest vibrating with the bass notes.
I am trying Amazon HD music for free. I am having problems with it loading some times and not always working well with CarPlay. It also seems to take more data than Spotify. Starting to feel like Amazon HD music it’s just not worth all the hassle. I will say the Sign by Ace of Base does sound great in either format,cranked up on the ML system,if you like bass.
Have you installed the latest updates to the Amazon app? To iOS?
Amazon HD tracks are much higher resolution. That's why they sound better and also why they take up more data. I download Amazon tracks to my iPhone at home on WiFi for free. When I'm in my car, I switch the Amazon app to Offline Mode. I use no data at all. My data plan for my iPhone (which I only use for the car) is $7 a month.
