Dual Climate (using voice)
Does anyone know if there is a voice command you can use to turn OFF the dual climate setting. In my wife's RX there is a hard button, but on the ES and the LS you have to go into the menu to turn it off and bring the temperatures in Sync
Where is the hard button in the RX?
Thats one quirk of the 7ES i hate... the DUAL climate mysteriously coming on when i'm alone and going through 9 menus to turn it off, except when i click on "Dual" it doesn't respond and two temperatures persist on the display.
You need not go through nine menus. Merely set right side screen to climate and deselect DUAL.
yeah tried that which leads to the same menu to turn off "DUAL" but even when i deselect it, nothing happens and two temps remain on the display. i have to fidget with it for what seems eternity to get it to deselect. sometimes i just give up. i just want it to stay as i set it and not change
Climate Control side display on 12.3 inch display
Putting the trackpad cursor on "DUAL" and click will (or at least it's supposed to} toggle DUAL mode on or off. When DUAL mode is off the passenger side temperature should synch up with the driver's side temperature setting.
Also, if you aren't already aware of it, On the air conditioning control screen's "Main control screen" the "DUAL" word is merely an indicator of whether DUAL mode is on or off. You can try to click on that word from now 'til the heat death of the universe and nothing will change. When on the "Main control screen" there are two means of changing the DUAL mode setting:
1. On the submenu list, select the three dots item that will take you to the "option control screen" where the "DUAL" word is a control toggle to turn the mode on or off.
2. Press the sub function button (just to the rear side of the trackpad) which will pop-up a word list containing amongst other words "DUAL" which is also a control toggle to turn the mode on or off.
Lastly, the air conditioning settings register to the electronic keys. From the owner's manual (on page 253 for the 2019 version):
■ Registering air conditioning settings to electronic keys
- ● Unlocking the vehicle using an electronic key and turning the engine switch to IGNITION ON mode will recall that key’s registered air conditioning settings.
- ● When the engine switch is turned off, the current air conditioning settings will auto- matically be registered to the electronic key that was used to unlock the vehicle.
- ● The system may not operate correctly if more than one electronic key is in the vicinity or if the smart access system with push-button start is used to unlock the passenger door.
- ● Vehicles with the driving position mem- ory: The doors that can recall the air con-ditioning setting* when unlocked using the smart access system with push-but- ton start can be changed. For details, contact your Lexus dealer.
Yes in our RX but not in our ES.
