What Just Happened?
Yes, absolutely. Fob remains in car, in our garage, 24/7 except when parked out in the world. Do the same thing with our Volvo and Audi. You mean fob cannot be left in car at night or when we’re away, then? Wow. That’s something I didn’t know and also explains why fob battery only lasts six months, (though a year or two on Volvo and Audi). Thanks!
I'll guess that there is something in the manual warning you not to store the fob in the car.
Leaving the fob in the car not only drains the fob battery, but it can also drain the car's 12 volt battery because, as long as the fob is in the car or even close to it, the fob and the car will be trying to communicate with each other constantly. That could well be why you needed to replace the fob battery after such a short period of time.
Beginning on page 92 of the 2021 manual, there is a lengthy discussion of the keys. It does state that the key will enter a low power mode if it is left too close to the vehicle for more than 10 minutes so that seems to contradict the low battery idea (assuming the electronic key is working correctly). It also has some information about the key touching metal objects that may interfere with communication. It also states that you shouldn't leave it on the dash and that coin tray could be considered part of the "dash"? Might be worth a scan to see if any of it applies to your situation. Could have just been some strange fluke as there isn't anything I can spot in the manual that identifies a clear smoking gun. I only did a quick scan however...
Perhaps a bad battery to begin with - NEW means Never Ever Worked!
LexFinally (09-01-21)
I just read the very similar section of the manual for my RAV4. From my reading, I think there is a difference between the "low power mode" and the mode that disables the fob. I think that, in the low battery mode, there is still some battery power being used by the fob. Only disabling the fob eliminates any battery usage at all. I also noticed that at least one paragraph in that section applied only to hybrid vehicles, and I think that the OP has an ES350.
The thought that also crossed my mind is the manual would be more useful if it had been written by someone with a greater proficiency in using English than what appears to be the case.
Never really thought about this until I read this thread but in my manual it does state Do not attach metallic or magnetic
materials to the keys or place the keys
close to such materials. I have always had my metallic keys attached to the metal ring that came with the fob with no problems. If there statement is true why did they have a metal ring attached from factory. Do others have keys attached with no problems.
That said, fob battery preservation, and the fob being able to communicate with the car are separate issues, but related. The fob battery will last longer if it is kept out-of-range of the vehicle's receiver/transmitter, when not in use (as I reported, my fob batteries last about five years). The other issue is to avoid shielding the fob's transmissions, as this will deplete the fob battery faster.
If one's fob is in one's pocket or purse, behind one's phone or keys, and the fob happened to have a weak battery, one may need to take it out and place it close to the start button, but, maybe not, if the fob battery isn't low.
Sorry if I'm over-explaining this!
Just store the fobs in a Faraday pouch when at home.
Do your Audi and Volvo have keyless ignition/push button start? If they do, you would have battery drain if you stored their fobs in the car. On the other hand, if they have a traditional ignition that requires inserting a physical key into the ignition, storing their fobs in the car would not cause a problem because their keys/fobs are not constantly communication with the car.
I suspect that it would take a large amount of metal to interfere with the operation of the fob. While I've never attached anything at all to the fobs for cars with keyless push button start that I've owned, I've always kept the fob in one of my pockets, and it is the same pocket where I keep my keys. I've never had a problem with doing that, and my fob batteries have typically lasted for 4+ years.
