Rear Camera Detection Unavailable
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
Hey guys,
I left my car about three days, and when I got back, I started the engine and it took longer than usual to start as if the battery is weak. After that, a message showed up on the display saying "Rear Camera Detection Unavailable" And looks like the battery is the main cause of this problem, even though I checked on the battery exactly two weeks ago, and it was "Okay" and no replacement is needed.
Anyone of you guys have solved this issue? I tried to put the car in reverse and turn the steering wheel to the max left, and then to the max right, but this has not solved the issue. Also, I cleaned the rear camera and tried the steering wheel thing again, still did not work. Also, do
I need to replace the battery since it took longer time when I first started it? And btw, I shut off the engine on and turned it back on, and the engine start was smooth.
Problem solved: just after replacing the battery, I did the steering wheel thing and the message disappeared.
Three things happened just before my battery (F Sport) died, other than the start-up just wasn't right.
The driver's seat wouldn't operate, only the driver's window would open and the display for the rear camera had limited functionality.
The next time I went to start, nothing.
Problem solved. Went to test the battery and the battery was DEAD, even though I checked on it two weeks ago! Anyhow, everything is good now after replacing the battery. Much smoother engine start and the RCD message disappeared.
