2019 Lexus ES350 No Sound coming out of audio system
Hello
I bought a 2019 ES350 6 months ago. I got hit from back, the body shop replaced the rear bumper plus the blind spot radar and one park sensor. They also replaced all wiring harness with brand new one. Now all the sensors are working perfect, no problem at all. I picked up the car last week, then noticed that the audio system is not working. I can switch to radio or connect Bluetooth but no sound coming out at all. Also when I turn the volume **** or using steering buttons, nothing happens. It doesn't show anything on the screens, looks like the volume is not working or so. I brought the car back to the shop, they said what they've done has nothing to do with the audio system. I just want to see if anyone can help me on this problem before I lose my hope and bring it to a dealership and spend thousand of dollars extra "we all know how they work". Thank you in advance
Kevin
Kevin
The amplifier is located under the driver seat. Maybe the wires are damaged or they are somehow disconnected. I will check that first.
Also, in the trunk you have two condensers. I would check them too.
Hello
Kevin
Kevin
Also, in the off chance your 2019 had one of the ill behaving Panasonic head units that didn't get the available software updates that fixed the problems. The car complaints summary LEXUS TSB #L-SB-0022-19 and the full NHTSA posted TSB pdf Navigation Update Phase 3 (Panasonic) describe the problems, one of which is "Volume button stops responding" and how to check if the TSB applies to a head unit (See step 1.F and Figure 5).
That's so weird, I had my car hit and repaired by the bodyshop at the dealer and some issues weren't there before the accident and trying to tell service dept to fix it they didn't want any part of that so the bodyshop had to do it, then service did it and messed it up even more. Finally service fixed what they messed up but the issue when it came back from the body shop was still there (a rattle) so I left it. Just fyi you may get back and forth from service warranty and the shop.
