What quirks/annoyances do you have with the 7ES?
#331
My issue is at night if you're fueling up it's hard to find the fuel door release button in the dark. In NJ, we don't get out of the car as self serve is not allowed.
#333
#334
I would say the port where you plug you iphone/usb cable does not make sense as you cant close the nice wood lid and use the usb outlet at the same time.
go in your car and see the difference with the lid closed and opened. With the lid closed it compliments all of the other wood trim.
usb should be moved to the center storage or at least dropped down so the lid can be closed. bad design "visually", great design for functionality
GS350Miami (10-10-22)
#335
Absolutely right. Almost didn’t buy this car because of the exposed cables and visible mess. I think 2023 brings wireless Car Play. You problem will be solved with the next ES you buy.
#336
Biggest annoyance, parking assist. The parking sensors show 4 bars I believe, when it gets to the second bar, the emergency park assist already slams on the brakes and then I continue to inch forward until I get to 1 bar on the parking sensor monitor. As if the beeping wasn't enough, the parking assist kicks in too early. I haven't bothered to look for a way to deactivate it yet though.
#337
I was just writing in another post about how I do a lot of city driving and:
- This is a great reason to have a system that prevents you from backing into a person--there's always kids running around
- This is also tricky if you're trying to wedge your car into a tight spot and the system thinks there is a person there when there isn't.....A unique example that I wrote about in another thread is backing up to a row of plants that are blowing in the wind--the system is likely detecting the motion and it starts becoming super sensitive.
#338
#341
#342
I'm sure a lot of people saw this, I meant to post a lot sooner. But anyway here's the next-gen Camry... not much to see.. but it's something. This should be very crucial to the 8ES. See anything you like/dislike on this?
#345
I notice these interesting lines. Yes it won't be 100% grafted onto 8ES, but it gives you an idea of the design direction for 8ES. Even then, It's interesting. I can tell this car will look good from my highlights below. the third hood line didn't stick. damn MS paint. but you get the idea.
