2019-2022 ES300h engine oil and filter replacement
not true, that is from the carcarenut.
You can use anything specified in the Australian and many overseas manual:
The only issue is the 10w-30 oil for cold starting below 0 F or -18 C.
And before anyone who jumps up and down and say their USA manual only says 0w-16, that is due to CAFE and has nothing to do with the actual engine.
I totally agree that 0w16 is solely for CAFE. But even the maintenance booklet scares you. It literally says that if you have to use a viscosity other than 0w16 in an emergency situation, to go back to 0w16 as soon as possible.
ViktorG (01-05-22)
The more videos I watch from the car care nut the less credible he sounds to me. I think at this point he's just creating content to grow his channel and make money.
I know our local Lexus dealer (I’m not in the US) uses either 5w-30 or 0w-20 depending on the engine for all scheduled maintenance. Apart from like likes of ISF and GSF where they use 40 weight. Does not void warranty and meets the specs of our user manuals just fine.
Hi Viktor,
I follow this guy on youtube who is a master tech at toyota and he says that only 0w16 oil should be used and anything else can cause problems with the engine because it was designed to only use 0w16 oil. Is this true? I would like to use 0w20 or even 5w20 in this car. Its a 2021 ES300h
kingofire (01-06-22)
I'm not a thin oil guy. I believe that this is just for CAFE reasons. My belief has always been that in order to minimize wear always use a oil with HTHS of 3.5 or greater. The 0w16 has a HTHS that hovers around 2.6. There are many SAE articles that say that any viscosity below HTHS of 2.6 sees drastically increased wear. So for this reason alone I'm really not comfortable using 0w16.
You can be thick or thin oil guy, but that doesn’t change the fact that A25A-FXS is a 0W16 oil engine. It was made by Toyota, they know what they are doing so I am not thinking about beeing smarter than them.
One of the components that will not like thick oil is the variable oil pump.
The car must work for you, not the other way around. Don't lose sleep/thinking power etc trying to change things up and play mad scientist/engineer in your basement. This is what engineers get paid for. Toyotas and Lexuses are the height of "set it and forget it" type cars. They're the exact cars more so than any other brand you buy to just drive and relax.
The whole reason I gave up my extremely maintenance heavy BMWs for Lexus hybrids. I want a ZERO THINKING car. Get in and just drive =)
Oil viscosity on these cars are absolutely none of your business, nor should they be. Yeah if you want you can tweak this or that oil and likely be fine, but really, you're wasting your time. Don't waste your thoughts.
I don’t think its right to judge if someone is wasting their time or not. If someone wants to write a PhD thesis on HTHS and viscosity for the A25A engine then so be it. The world is better for it. In the software development world, real engineers listen to end user feedback and concerns and addresses them.
hammerme (01-07-22)
Hello again,
I am a Lexus Master Technician and I am creating a series of maintenance/repair tutorial videos covering the 2019-2022 Lexus ES300h models.
Here is my video showing how to replace the engine oil and filter on ES Hybrid models.
Please hit me up with suggestion on what other things you would like to see in the video comments.
Cheers!
Viktor
Cheers!
Viktor
thanks and cheers
One must have an inquisitive mind to grow in knowledge and experience.
I've been in and around actual track/race super high hp cars where you actually do benefit to some degree (even then its pushing it) by playing oil hipster. our grocery getters aren't those.
Toyota takes their reputation extremely seriously and you can bet they've done the secret studies based on secret internal data using the strongest supercomputers in the world on their bread and butter powertrain. Whatever you thought of, they thought of years in advance. The complexity of the entire package was already studied on a molecular level. Trust me bro-jerking your oil selection thinking you've got the answer to an even better oil viscosity is wasting your time and could quite possibly backfire on you.
These powertrains are used on taxi fleets on Camry hybrids all over Asia racking up 600k+ miles. The fleet techs eat their lunch, dump in what the factory tells them and move onto the next. Exactly what we need to do in our Ferraris.. i mean Toyotas.. i mean Lexuses.
where and how exactly do I pull, I don’t want to break any latches lol they’re quite brittle being hot and cold all the time, I can tell that’s probably a close to $300 piece of plastic lol. And I don’t feel like reading the manual lol 😂. Help me out please.
I just want to check make sure no animal sleeping nest there, and do an engine bay details clean up. I wonder if there is any insulation underneath or just bare metal.
