Significant impact of tires on noise and comfort
For me, the Pirellis are probabaly great if you're not in the Northeast or Midwest. If you are, I'd do these, the Michelin Primacy or Michelin CrossClimate 2. Just me.
Moorekx (03-02-22)
Vredestein Quatrac Pro. They have a short life, but a reputation for being outstanding at putting accelerative power to the ground. Even at that, there are no miracles when you channel 302 horses through two tires with no limited slip — it's still easy enough to spin 'em. On the positive side, ride and noise comfort are better than you'd expect from a performance-oriented tire with winter capability. I think soft rubber is the explanatiion for all of the above.
LexFinally (03-03-22)
My Hybrid also had Michelin A/S Energy saver. I think they most likely fit Hybrids with Michelins and ES350 with Bridgestones. Tire Rack is a good place to find road test results and data from verified customer reviews. From my research, the new Pirelli P7 AS Plus 3s are the way to go if you want something well rounded with focus on quietness and comfort.
21 Hybrid. Michelin Energy. They're quiet, ride nice. Traction is on the low side. But don't care enough to replace them before they wear. The only annoying thing is the little slits on the side which make the tire hard to clean.
Both of our Lexus models (ES and RX) came with Michelin tires and neither one did well on tread life. Both now have Goodyear Maxlife Assurance tires which are far superior (ride, noise, wear etc) to the oem Michelins.
My Michelins have DOT4619, so almost 3 years old, but they roar like crazy.
All that said, glad you're having a good experience with your Goodyears.
Key phrase there is "OEM." The carmakers exercise enormous control over the design criteria of many OEM tires, and some perform differently than aftermarket tires that carry the same model names. In the case of Michelin Eco Energy Savers, independent testing has rated them far lower in multiple performance categories than other Michelin tires available for our cars, including Premier and CrossClimate II.
TLDR; stock Bridgestone tires are garbage! Change them if you care about comfort and road noise
I have had a 22 ES350 UL for the past 2-3 weeks coming from a 21 300h Lux and immediately noticed more road noise and harshness on road imperfections. My new car (ES350) came with Bridgestone Turanza El440 and the previous 300h had Michelin eco saver A/S on them. After doing lots of research, ended up choosing Pirelli P7 AS Plus 3 as probably one of the best tires out there for comfort and noise. They were replaced today and I took a ride and the difference is night and day! Basically there's no tire noise on smooth pavement. Even with music/radio off, I hear wind noise and engine noise and nothing from the tire. It also a lot more comfortable over bumps and small road imperfections. I am shocked that Lexus delivers cars with that garbage of Bridgestone tires as they are shooting themselves in the foot! Spent around $870 total including replacement labor and to me it was worth every penny.
I will never buy goodyears again. I had some goodyear assurance on another car and hydroplaned like crazy.. lucky i caught the slide right before hitting the guardrail and without any of the cars behind me on the freeway colliding with me. I had just got the tires.. i took them back and used the warranty to switch brands.. and the manager told i was the second to come in that month with the same issue. The treadwear is suppose to be good but the rubber compound is too hard in wet conditions. I hope you have better luck than i did.
my 2022 UL came with Michelin eco savers on the noise reducing wheels. they ride smooth and quiet. I prefer michelin with pirelli as my second choice.. ive run those P7's on another car. i dont really like how the P7 have a more rolled sidewall with less rim protection. i like the more vertical design of the michelin sidewall.
