The Rattle Battle
#31
I have the same rattle under that top leather piece above the instrument cluster. it's only at very low RPMs with load (the strongest area of engine vibration) so only a very narrow window which it happens as the engine goes up in RPMs, there's no more vibration and thus no more rattle. so happens like a split second, and only at certain times. like between 10-15 mph. so i haven't bothered to look at it. I bet that top leather piece comes off easily and i'll bet there's some plastic under there to dampen. i'll check it out one of these days.
I have the same rattle. Were you able to find the source of it?
#33
#35
I thought we talked about this in another thread. yes i solved that rattle above the instrument cluster. the leather piece takes 3 seconds to pop off. put some insulation underneath (tape, foam, an old sock, whatever you have) and put it back. No noises since.
#37
I did that last night so I will drive it later. I put foam and felt.
#38
LexFinally (05-09-22)
#39
Anyone else got a sun visor rattle? I had the dealership fix it once, but it's back. They had tightened the screws, but now that I know how to undo the cover. I figure I would take the screws out and add some blue threadlocker to it to see if that helps. The "fix" worked for about a week.
Update:
I tightened the screws that hold the sun visor in but that didn't seem to fix the issue. The rattle seems to be within the visor itself, possibly from being able to extend it out. Maybe I'll look for a way to disassemble it.
Update:
