Mark Levinson Bluetooth Audio Codec question
I know this is most likely a waste of my time but wanted to see if anyone knew what CODEC was being used for Bluetooth on our ML system? I usually stream music from Tidal and was looking at my cell phone CODEC options. The Default setting is SBC for me with options for others such as AAC, AptX, LDAC and so forth. Is there any way to find out what the default is and if it can be changed? I looked through the entertainment system manual but found nothing that mentioned this. I also looked at my Bluetooth settings in my car.
I'm fully aware of codecs and I'm not saying its new! HFP, SPP, OPP, PBAP, A2DP, AVRCP, MAP are different functions of Bluetooth and do different things. It doesn't answer my question though and I did see this in the manual. Thanks for trying to answer the question though.
You might also find from this What’s the Difference Between Bluetooth A2DP and aptX? article of interest:
...The A2DP standard operates in stereo and supports most of the standard audio compression codecs. The recommended sub-band coding (SBC) codec supports up to 345 kilobits per second at 48 kilohertz. That’s approximately one third the quality of standard CD audio—roughly the equivalent of a high-quality MP3 recording. Due to high “lossy” compression in the SBC codec, the reality of the audio quality is considerably lower, somewhere in the range of 256kbit/s.
The system also supports other popular methods of encoding and compressing audio, like MP3 itself. If the audio source is already compressed in a format like MP3, AAC, or ATRAC, then it doesn’t need to be re-encoded in SBC in order to be broadcast from the source device. With A2DP’s maximum audio bandwidth of 728kbit/s, it’s at least possible to start approaching what we’d call “high-quality audio” with the basic standard alone. (CD quality audio, uncompressed, is approximately 1400kbit/s.)...
A correct implementation of Bluetooth 5 is supposed to be backward compatible to ealier versions. Either the fitness band engineers screwed up the implementation or perhaps they got the implementation right but required a Bluetooth profile that your older phone didn't support.
A correct implementation of Bluetooth 5 is sipposed to be backward compatible to ealier versions. Either the fitness band engineers screwed up the implementation or perhaps they got the implementation right but required a Bluetooth profile that your older phone didn't support.
