2019 ES350 hesitation on acceleration
I am looking at buying a CPO ES 350 2019. I did a test drive yesterday and I noticed that the acceleration is not smooth as expected. When I am doing about 30 miles an hour, I push the pedal steadily but the car keeps doing the same speed for about 3-4 seconds. And then the car zooms about 3-4 seconds too late. This was a very jarring behavior. The salesman of course said there is nothing wrong with the transmission and everything is fine. But I cannot ignore this as I tried the same thing 3-4 times in Sports and Normal modes. I am going to back to pick up the car today but I have told the dealer to have the shop look at it. Thoughts?
That is a red flag there. It isn't normal. That car is most likely dealing with a fuel/air mixture that is too lean. Don't sign anything until you take it to an independent mechanic to have a full inspection done.
The following 3 users liked this post by UltraLux22:
The following 2 users liked this post by mikemu30:
dklanecky1 (04-08-22),
yelloguy (04-07-22)
That is not normal, 3-4 seconds is waaaaay too much.
LexFinally (04-07-22)
Fuel Injected cars "learn" from your driving pattern and adapt. If you always drive hard it will be ready
but will be hard to maximize MPG when you decide to drive gently. With this example it is possible that
the former owner and then the lot personnel just drove slowly. It learned to ramp up the throttle response
gently. Once you own it you might try to disconnect the 12v battery for 10 minutes to clear the memory.
This will also clear radio stations etc, but you have not really "moved into" this one yet, right? Once reconnected
you can begin driving at your normal pace and see how it accommodates you. Earlier comments here may well
apply, could be fuel pump/filter, air filter, sub-par fuel (only needs 87 Regular anyway).
On these cars removing the battery will not reset anything.
Thanks folks! Great inputs.
The salesman says he had his tech drive the car and the tech thinks there is nothing wrong with the car. Everything is normal.
I spoke to the salesman on the phone and he insists that the car is fine. He says he has owned an ES 350 and these transmissions respond the same way he watched it respond to me.
The car does have pep so when it responds it shows the power under the hood. I am wondering if I am imagining things here.
Because of all this back and forth, I could not keep the appointment today. So now I am going back on Saturday.
The following 2 users liked this post by UltraLux22:
LexFinally (04-08-22),
yelloguy (04-07-22)
The following 3 users liked this post by CJS57:
This is so awesome! I am glad I posted here. I was short of ideas and now I have several to work with.
Best part of owning a Lexus seems like I get to join this community! Hopefully I will graduate to learn the club lexus secret handshake in 4 years.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
This happened to me a few times recently when I tried to accelerate quickly after coming to a stop (like at a stop sign). When I pushed on the accelerator, the car seemed to hesitate for about three seconds. At first, I thought it had something to do with the car being stuck in a higher gear, but this wasn't the case. The issue seems to have gone away after I started driving consistently in sport mode.
I plan on reporting this issue during my next visit to the dealership and will let you know if they find an issue.
yelloguy (04-08-22)
If there were anything wrong with the fuel mixture (highly unlikely anyway) you'd have an STFT and/or LTFT codes. Not likely on such a new car anyway unless a bunch of rats attacked the engine or you drove into a light pole--in other words something terribly obvious.
My guess is just the OP is used to a certain kind of response from sportier cars and/ or not used to a stepped auto on a Lexus. His description of 3-4 seconds is obviously perceived then translated through his brain then a keyboard then onto the forum. I don't think he took a stop watch out to time it lol.
Even with my 2016 IS200T F Sport, a very sporty car, I would "perceive" a similarly long delay when flooring it. One mississippi, two mississippi, three mississippi...shift... ok folks lets accelerate. it was always frustrating if i wanted to pass someone, but if i waited long enough for the power to build up, then would come the satisfaction.
Not to turn this into a 350 vs hybrid thread but it is objectively one of the things i appreciate about the hybrid drivetrain. while outright measured acceleration #s may not be as fast over a timed period (I'll give the 350 that), the response with the hybrid *when you want* to go, is instantaneous as the electric motor spins up -- say if you want to merge into traffic or pass someone. It's always gratifying not having to wait for a computer to perceive the signal to shift, execute the actual physical shift, *then* accelerate.
TL;dr, more than likely what OP is experiencing is normal.
There's maybe a one second delay when I pound the pedal - three or four would be outrageous.
