2022 ES Window Warranty Voided?
Speaking of weird responses none of this is true. Tint shops often remove the rubber glass run for better access, and remove the door panel to get the weather stripping (fuzzy wiper) out of the way. It is ideal to remove the glass completely but generally not practical.
If you don't think so visit any tint shop and look at the cars in the service bays you'll see doors in various levels of disassembly.
If you're uncomfortable about getting windows tinted it's a good idea to avoid it because things can happen, but it doesn't mean they will happen. Good tint shops install window film all the time without removing door panels. I use two reputable shops and have never had any issues related to their work but again something might happen but it's not something I worry about.
I had PPF put on my plugin Prius (the guy came to my house which was cool) and the guy told me he would take out the door glass to tint the windows. I wasn't looking to do tint I was just asking him Qs about it.
I've seen tint install videos on YouTube where they remove the door panel and remove the weatherstrip around where the window goes to better apply the tint.
I think you should go to another dealership and see what they say.
@omara2 Sorry you were having issues with your glass warranty. Hope that you were able to work it out. I took my recently purchased, low mileage, 2022 ES350 in for a complaint of wind noise and the tech found a tech bulletin about bad left quarter panel with the fix being a replacement. It fixed my wind noise problem. My windows are not tinted so no issues that way, but I thought I'd mention it so you can tell them that they'd not done what the technical bulletin called for, which is replacement not adjustment... whatever that means. Good luck!
LexusSara
04-18-16 08:59 AM
jkutti2000
ES - 5th Gen (2007-2012)
07-18-11 05:18 AM
