ES - 7th Gen (2019-present) Discussion topics related to 2019+ ES models
Mark Levinson Audio - Top Ten systems
Old 04-13-22, 01:50 PM
bdroc
bdroc's Avatar
Default I like ML
Originally Posted by UltraLux22
I found this article rating Auto Sound Systems. It mentions the ML in the LS but even at 1800 Watts in the ES, that's still darn good! IMHO
You can read the article here: https://www.autobytel.com/car-buying...stems-134063/#
You'll find the Lexus system on page 2.
My Lexus ML system is better that the Bose system in my Cadillac. Average sound playing XM but much better streaming. Amazon music sounds great.
Old 04-13-22, 01:55 PM
Mike728
Mike728's Avatar
Originally Posted by mikemu30
Truly no comparison. XM is fine and clear. The MP3 sound scratchy.
That makes absolutely no sense. You may have an issue with your system. Is it a ML?
Old 04-13-22, 02:04 PM
mikemu30
mikemu30's Avatar
Received 2,572 Likes on 1,829 Posts
Yes indeed. Cmon
Old 04-13-22, 02:05 PM
mikemu30
mikemu30's Avatar
Amazon music does sound terrific. I don't stream it enough.
Old 04-13-22, 05:14 PM
Mike728
Mike728's Avatar
Yes indeed. Cmon
Not entirely sure what your response is, but I'll assume you have a ML and you think XM sounds better than your MP3 files. Can you please tell me what bitrate you're using? Because, there's no way XM will ever sound as good as a 320 Mbps MP3. Not even close...
Old 04-13-22, 05:17 PM
mikemu30
mikemu30's Avatar
You're insulting my intelligence asking me if I'm sure it's ML. I've owned this car longer than most members on this site. Copy that XM sounds quite clear and the MP3s on the flash drive sound awful.
Old 04-13-22, 05:26 PM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,325 Likes on 1,416 Posts
I'm with Mike728 on this - not the question if you have a ML or not, but that something is wrong if a decent MP3 sounds worse than XM. May not be with your system, but with the source material or media or something.
Old 04-13-22, 05:36 PM
Received 3,058 Likes on 2,570 Posts
Properly encoded 320 Mbps mp3 will sound very close or indistinguishable from CD quality.
Old 04-13-22, 05:39 PM
Mike728
Mike728's Avatar
You're insulting my intelligence asking me if I'm sure it's ML. ...
I'm sorry if you felt I challenged your intelligence. I don't believe I ever asked if you were sure you had a ML, just "if" you had one. Thank you for confirming it.
Old 04-13-22, 06:05 PM
mikemu30
mikemu30's Avatar
Got it so I suppose it's the media on the flash drive. They were simply exported from the PC to the drive and most were converted from CDs. Perhaps I used the wrong approach (my knowledge of this stuff is limited) but I assure you that source is horrendous quality on the ML - but get this sounds fine in my wife's RX which does NOT have the ML system.
Old 04-14-22, 12:51 AM
703's Avatar
MP3 is an encoding format. Does not say anything about the audio quality. You must have listened to low bit rate MP3s from the 90s.
I can encode MP3 to 320kbps which is indistinguishable from a CD. Also CD is low quality by todays standard where lossless audio or high resolution audio is the gold standard.
kalel2127 (04-15-22)
Old 04-14-22, 02:52 AM
ESh
ESh's Avatar
Received 1,050 Likes on 780 Posts
ML in my 2020 ESh sounds amazing. That's all I can say.
wmoor004 (04-14-22)
Old 04-14-22, 04:12 AM
703's Avatar
Using the USB connection from an iPhone or Aux port is the best way to enjoy the ML. Great improvement over BT.
Old 04-14-22, 04:20 AM
ESh
ESh's Avatar
I use flash memory and FLAC songs. That’s where ML shines the most.
UltraLux22 (04-14-22)
Old 04-14-22, 05:29 AM
ionian
ionian's Avatar
Yeah one easy way right now is to go download free hi-res sampler from HDtracks at https://www.hdtracks.com/#/album/61d...947355ea247555
These are professionally encoded in 96KHz at 24bit. The proper way to bring out the ML.
Quick Reply: Mark Levinson Audio - Top Ten systems
