Remove "hybrid" letters from es300h
Is there any way to remove or have the "hybrid" letters removed from the side of the es300h? Not sure if it's a "sticker" or something else.
Thanks
Thanks
They're emblems and just like any other emblems I believe they're held on with just some double sided tape/glue. Heat + Fishing line should take care of it. I plan on doing the same..
ESrob (05-22-22)
Took ours off. Blow dryer and on high heat setting keep on each letter for about ten seconds. Then they will pull right off or twist off. You will then need Goo Gone or another product to get off the remaining adhesive. Good coat of wax and you are done. A 20 minute job.
That was the first thing that I did on my 2019 ES300h UL since I didn't want to be too ''flashy'' with the Hybrid badgings. I blow dried it on high heat for a couple of seconds and used a dental floss to remove the letters. I used a tiny bit of WD40 to remove the excessive adhesive and immediately cleaned the area with a car shampoo to remove the WD40 residues just in case. A big plus if you are doing it on a hot day during summer like I did (didn't even take 5 minutes to remove both badges).
