What went wrong with your car?
#31
Wow the extended warranty debate is spreading like cancer here
LexFinally (05-31-22)
#32
That's a misquote, glam. No one ever said that. The voluminous thread here was about whether having an EXTENDED warranty AT EXTRA COST was worth is, because they believed the odds were against having enough things on these particular vehicles break to justify the warranty's price.
For the record, I would not accept buying a new car without a warranty, yet I did not agree to pay extra for an extended warranty.
Back on topic, I've had exactly one problem: seat memory that didn't memorize from the factory. A dealer reset fixed it.
The seat memory function can be reset? My 6-week old 2022 UL just developed that problem a day or two ago, worked fine originally but for some reason now the recall memory doesn’t respond. I was planning on making a service appointment but curious about your experience. Is this one of those things only the dealer can reset?
#33
2020 ES 300h Luxury leased 9/5/2020
a) January 2021 noticed the passenger seat "tilted" inward. Secure and tight, just at a slight angle.
Long thread here in CL, seems to be limited to Kentucky built Flaxen Interior cars. Fixed OK.
b) October 2021 sunroof rattle. Tightened screws and all's well. Same noise in our last generation
2018 ES 300h that was also easily fixed (and did not return)
Overall extremely nice and improved over our 2018 and 2014 ESh's. Getting 51 MPG in the summer
and 44 in the (Chicago) winter on E10 fuel. 20250 total miles at 20 months, going to buy out this lease
when the time comes.
landonm86 (05-31-22)
#34
#35
For me, the feature never worked from the time of delivery. The dealer didn't know sight unseen exactly what would be required to fix it, but did some kind of reset with what appeared to be relative ease. I knew it wasn't working because my previous card had the feature and I was used to using it. I supposed at first that it was me misusing it somehow, but kindly people helping out on this board as well as a recheck of the owner's manual confirmed that no, it just wasn't working. And to your question, I'm not aware of any way for anyone but the dealer to reset that system.
The following 2 users liked this post by mikemu30:
ATL350 (06-01-22),
#36
I think I saw it at the time. I don't recall why I either concluded it didn't sound applicable to my situation, or tried and failed to do it. Maybe it was just inertia that the dealer had that nice shiny warranty. :.)
#37
Always fun to return to the dealer especially if they serve decent bagels
#38
#39
LexFinally (06-02-22)
#40
420 miles.
developed a rattle on the passenger visor. Took it in and got a loaner.
Also noticed the driver side door takes a bit more strength to close so it might be off alignment. Asked them to check it out too.
#41
Are these current problems, or did they already succeed/fail in fixing them?
#42
#43
They did have to deal with a few rattle and door issues. As for my 2022 Ultra Lux., I haven't had a single issue other than the ridiculous wireless charger not charging with its case on. *** The details of that were explained more comprehensively in another thread. ***
10 MILES
DATE 12/2019
SERVICE: REPLACED BATTERY
DESCRIPTION: REPLACED BATTERY ~|~CUSTOMER STATES THE BATTERY HAD TO BE JUMP STARTED. PLEASE CHECK AND ADVISE ~|
1285 MILES
DATE 01/2020SERVICE: INSULATED LEFT REAR DOOR
DESCRIPTION: INSULATED LEFT REAR DOOR ~|~CUSTOMER STATES RATTLE FROM LEFT REAR WHEN DRIVING ~|~FOUND EXCESSIVE CLEARANCE IN DOOR PANEL ~|~1277 FOUND EXCESSIVE CLERANCE BETWEEN LR DOOR PANEL & DOOR FRAME, CAUSING A RATTLE REMOVED DOOR PANEL & INSULATED WITH FELT CB READ LESS
1409 MILES
DATE 01/2020DESCRIPTION: FOUND THE PLASTIC CAP ON THE LR TRAILING ARM FORWARD MOUNTING BRACKET HAD COME OFF AND THE CAP WA
SERVICE:
DESCRIPTION: FOUND THE PLASTIC CAP ON THE LR TRAILING ARM FORWARD MOUNTING BRACKET HAD COME OFF AND THE CAP WA ~|~CUSTOMER STATES THAT NOISE WHILE DRIVING ALSO SOUNDS LIKE A LOOSE HEAT SHIELD. ATTENTION DOUG. ~|~ ~|~1307 FOUND THE PLASTIC CAP ON THE LR TRAILING ARM FORWARD MOUNTING BRACKET HAD COME OFF AND THE CAP WAS RATTLING AROUND IN THE FRAME POCKET. ATTACHED THE CAP TO THE BRACKET AND TEST DROVE, THE NOISE IS NO LONGER PRESENT. (DM) OUT MILES - 1409 READ LESS
SERVICE:
DESCRIPTION: FOUND EXCESSIVE CLEARANCE BETWEEN THE RR DOOR PANEL AND DOOR FRAME, CAUSING PART OF THE RATTLE NOI
SERVICE:
DESCRIPTION: FOUND EXCESSIVE CLEARANCE BETWEEN THE RR DOOR PANEL AND DOOR FRAME, CAUSING PART OF THE RATTLE NOI ~|~CUSTOMER STATES THAT THERE IS A RATTLING NOISE COMING FROM THE PASSENGER REAR AREA WHILE DRIVING. ATTENTION DOUG. ~|~ ~|~1307 FOUND EXCESSIVE CLERANCE BETWEEN THE RR DOOR PANEL & DOOR FRAME, CAUSING A RATTLE INSULATED RR DOOR PANEL CB READ LESS
SERVICE: FRONT DOORS OPERATIONS NORMAL, NO POPPING NOISE FOUND AT THIS TIME.
DESCRIPTION: FRONT DOORS OPERATIONS NORMAL, NO POPPING NOISE FOUND AT THIS TIME. ~|~CUSTOMER STATES THAT THERE IS A POPPING NOISE COMING FROM THE FRONT DOORS WHEN OPENING AND CLOSING THEM/ CHECK AND ADVISE. ~|~ ~|~1307 FRONT DOORS OPERATION NORMAL, NO POPPING SOUND AT THIS TIME CB READ LESS
4628 MILES
DATE 02/2020SERVICE: 5,000 MILE LIGHT SERVICE
DESCRIPTION: 5,000 MILE LIGHT SERVICE ~|~5,000 MILE LIGHT SERVICE ~|~COMPLETED 5K ~|~4628 5K SERVICE PERFORMED
SERVICE: REPAIR
DESCRIPTION: REPAIR ~|~C/S THAT THE TRACK PAD MAKES A CRUNCHING NOISE WHILE BEING DEPRESSED AFTER NOT BEING USED PLEASE CHECK AND ADVISE ~|~ ~|~4628 FOUND TRACK PAD WITH DEBIS AND NOISY CLEANED TRACKPAD AND APPLIED DRY LUBE
14302 MILES
DATE 12/2020SERVICE: LEXUS OF LEXINGTON MULTIPOINT INSPECTION
DESCRIPTION: LEXUS OF LEXINGTON MULTIPOINT INSPECTION ~|~LEXUS OF LEXINGTON MULTIPOINT INSPECTION ~|
SERVICE: REPAIR
DESCRIPTION: REPAIR ~|~CUSTOMER STATES A SURGING MOTION IS FELT WHEN IN STOP AND GO TRAFFIC OR SPEEDS LESS THAN 50 -60 MPH. PLEASE CHECK AND ADVISE. ~|~ ~|~14295 COULD NOT CONFIRM THE CONDITION, TEST DROVE VEHICLE 7 MILES, PERFORMED VEHICLE HEALTH CHECK. NO DTC'S OR DEFECTS PRESENT. RL READ LESS
SERVICE: REPAIR
DESCRIPTION: REPAIR ~|~CUSTOMER STATES CENTER CONSOLE SOUNDS LIKE ITS CRACKING WHEN WEIGHT IS APPLIED. PLEASE CHECK AND ADVISE. ~|~ ~|~14295 INSTALLED NOISE DAMPENING MATERIAL. RL
SERVICE: REPAIR
DESCRIPTION: REPAIR ~|~SAFETY RECALL 20LA01 (INTERIM NOTICE 20LB01) MULTIPLE MODEL AND MODEL YEARS VEHICLE MAY STALL DURING DRIVING AT HIGHER SPEED. ~|~ ~|~14295 REMEDY NOT AVAILABLE
SERVICE: REPAIR
DESCRIPTION: REPAIR ~|~PERFORMED 15,000 MILE SERVICE (SEE ATTACHED MENU). ~|
15616 MILES
DATE 03/2021SERVICE: 20LA01 - REPLACE LOW-PRESSURE FUEL PUMP (ES 350 19' AND 2
DESCRIPTION: 20LA01 - REPLACE LOW-PRESSURE FUEL PUMP (ES 350 19' AND 2 ~|~SAFETY RECALL 20LA01 (REMEDY NOTICE) MULTIPLE MODELS AND MODEL YEARS VEHICLE MAY STALL DURING DRIVING AT HIGHER SPEED. ~|~COMPLETED 20LA01 ~|~15616 BASED ON VIN NUMBER CAR QUALIFIES FOR 20LA01 COMPLETED 20LA01. (BJ) READ LESS
17320 MILES
DATE 05/2021SERVICE: F.DSC 1-SD (ON-VEH)
DESCRIPTION: F.DSC 1-SD (ON-VEH) ~|~CUSTOMER STATES PULSATION WHEN COMING TO A STOP. PLEASE CHECK AND ADVISE. ~|~RESURFACED FRONT ROTORS ~|~17320 FOUND FRONT ROTORS WARPED CAUSING BRAKE VIBRATION. BEFORE RUN OUT .03MM MACHINED FRONT ROTORS. VIBRATION IS GONE AFTER REPAIR. (BJ,AB,JL) AFTER RUNOUT .00MM READ LESS
SERVICE: F.DSC 1-SD (ON-VEH) COMB: OPPOSITE SIDE
DESCRIPTION:
SERVICE: HESITATION
DESCRIPTION: HESITATION ~|~CUSTOMER STATES A HESITATION AFTER RECALL WAS PERFORMED. PLEASE CHECK AND ADVISE. ~|~ ~|~17319 TEST DROVE AND COULD NOT VERIFY HESITATION AT THIS TIME. NO CODES STORED. SEE ATTACHED HEALTH REPORT
#44
Does anybody have jerky brakes on 300h while maneuvering at the parking?
#45
Haven't noticed any jerky brakes, but I am still getting used to driving the vehicle and especially for that last few seconds of braking when the pads make contact with the rotor. I do feel a "catch" or "grab" as I get to that point, so just learning to ease into it a bit better.
Edlcworld
06-08-22 07:56 AM
