Broken Oil Filter Canister - Is My Engine ok?
I’m not capable of changing my own oil on a vehicle because I don’t have the knowledge or know how. Im not mechanically inclined like some others in here, so I leave it to the dealership service technician to do it.
The following 3 users liked this post by mikemu30:
If someone is competent and handy then it totally makes sense to change their own own in their $40-$50 K Lexus, as means of satisfaction.
If not competent, i would spend the few dollars to have someone who is trained to do it.
Just my personal opinion.
I used to change my own oil but got tired of crawling under vehicles and taking the oil down to the recycling center. I figured that as I got older and since I purchased a "luxury car" that I would also benefit from the "luxury" of not having to perform my own vehicle maintenance anymore. To me it's worth the slight additional cost to have someone else do it now. For those who truly enjoy wrenching on their own vehicles more power to you. At least I have appropriate knowledge of automotive systems (from a previous career) to know when the dealer is attempting to extract more money from me and I know what to challenge but other than that, I am fine with having the dealer service my car.
Doing it yourself, competently, assures the job is done right (or even, at all) and no other damage to your car is done.
Anyone can monkey something up, including "professionals."
Personal responsibility =)
Also you can upgrade to a metal (OEM) canister IIRC.
At least on the hybrids, it's a simple metal screw on filter -- no stinking contraptions!
I actually feel just the opposite. I know if I change it - I will spend extra time after I’m done and before I put all the covers back to ensure there is no leak. I find it hard to put that level of trust in the average quick oil change shop. That being said, I have a friend that owns a lube shop here and they are outstanding and I actually do trust them. I also get to observe as they go about changing it. In my case I have them only add 6 qts and I add the extra .2 qts when I get home. Just call me a partial control freak….lol
I don’t understand. Why wouldn’t you take a brand new $50,000 to $55,000+ Lexus ES350 to the dealership and have them replace the oil and oil filter? Why take chances doing it yourself even though you know what you’re doing? I mean anything could break or go wrong doing it yourself. At least, at the Lexus dealership, they will be 100% responsible if they screw anything up on your vehicle.
Ask me how I know, with dash cam footage (unknown to the "techs")
These kids know almost nothing about your car either. There's few exceptions as with any profession.
chuyrobles (06-06-22)
I took my new Prius in for it's first oil change at the dealer. The tech scratched the front bumper putting It on the lift. Sure they repainted it but it was a hassle. I should have just DIY.
I have the dealer do the oil changes while the car is under warranty 3-4 years and then I DIY. That way if anything happens under warranty there are zero questions as to maintenance as it's all in their system. Outside of warranty I don't see much point in over-paying at the dealer...
I hope you understand that dealer techs are a bunch of $8/hr 18/19 yr olds cursin/spitin up a storm, bashing your doors in, swinging them open hard, slamming things, scratching things..working on your car while blasting horrible music.
LexFinally (06-06-22)
Now when did Toyota change the canister to be plastic? That’s a real cheap shot. I change oil on 3x Lexuses each year and the steel/aluminium canister is heavy and solid, is impossible to crack it unless you drop it from a top of a building.
when I do my own change, I torque to manufacturer specs, use the best oil and ensure oil properly drained, not spilled when filling.
however, here is the real industry secret. It is not your Lexus master technician who does the oil change, it is handled down to the lowest paying technician, who is normally someone with the least amount of experience. They do the job as quickly as possible, while charging you the full hour.
Don’t assume that going to a professional gives you a “professional” outcome.
I would do a better job, 100% of the time when it comes to oil changes.
