ES - 7th Gen (2019-present) Discussion topics related to 2019+ ES models
Can I buy this button somewhere (dash blank)
Old 07-20-22, 03:05 PM
LS500Fan
LS500Fan's Avatar
Default Can I buy this button somewhere (dash blank)
I want to turn one of these blank spots into a momentary switch. I looked on Aliexpress but could not find one that is meant to go there.
Do you guys have any suggestion on how to get a factory looking switch to replace the left or right blank?
Old 07-20-22, 03:12 PM
flowfaster
flowfaster's Avatar
Doesn't the euro ES utilize those blank switches? Maybe you can look there however I'm not positive. GL
Old 07-20-22, 04:41 PM
LS500Fan
LS500Fan's Avatar
I will check out the EU spec ES media photos and see, it's an idea worth investigating!
UPDATE: Sigh, they don't show the whole thing in any photo that I saw.
Old 07-20-22, 04:57 PM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,321 Likes on 1,414 Posts
was just googling to see if I could find and noticed another Lexus model (not sure which) has a very similar looking set that might also work if you strike out with those
https://northparklexusatdominion.wor...button-part-v/
Edit, although now that I look at them, they aren't curved quite as much as the ES you've pictured at the top and bottom
Old 07-20-22, 06:24 PM
LS500Fan
LS500Fan's Avatar
Found a high res pic from EU for 2023, they didn't show anything extra.
DaveGS4 has me wondering if another Lexus model uses those identical buttons.... hmmmm...
Old 07-20-22, 06:33 PM
grp52
grp52's Avatar
What year and ES model type (350, 300h, etc.) is the photo for?
My 2019 ES 350 UL has the working switches in a different location for the panoramic VIEW switch - on mine it is located in the far left position and not in the center right position shown in this photo.
I haven't seen a parts break down below the whole multi-switch assembly so finding just one individual switch may not be possible. I did find three "Switch, Switch Assembly Combination" part numbers with varying descriptions of switches (84970-33120, 84970-33130, and 84970-33160) but I don't know whether or not you can disassemble and reassemble the switch assemblies to get a switch combination arrangement to your liking. (The description for 84970-33130 sounds the most promising one to get 3 working switches in one assembly - "Description: With head-up, with surround view. Lane departure switch. ES350. With head-up display. With back monitor. ES250." - but still leaves one with unknowns of connector pin outs and wiring harness compatibilities.)
Old 07-20-22, 08:05 PM
LS500Fan
LS500Fan's Avatar
‘22 300h UL, the switches moved up there for higher spec ES’s for 22 & 23.
Old 07-21-22, 12:07 AM
ESh
ESh's Avatar
Received 1,050 Likes on 780 Posts
No market has all the switches. Max is 3 switches. You can have a combination of AC 100V, 360 and HUD. The other combination is HUD, 360 and Winshield heater.
Old 07-21-22, 03:41 AM
LeeSoFL
LeeSoFL's Avatar
You've piqued my curiosity. What's the momentary switch?
ATL350 (07-21-22)
Old 07-21-22, 07:13 AM
bc6152
bc6152's Avatar
Received 1,306 Likes on 909 Posts
What I would do is drill a circular hole right in the center of the blank and run your switch out the back. You could use a toggle or a momentary switch that would fasten right onto the piece of plastic. Or, you could use a pushbutton also. GOOD LUCK!
Old 07-21-22, 07:45 AM
bc6152
bc6152's Avatar
A momentary switch is one where whatever is connected to it activates with one push, turn, or toggle. Usually a button that is pressed once to activate.
Old 07-21-22, 03:14 PM
LS500Fan
LS500Fan's Avatar
A momentary switch simply allows electricity to pass as long as it’s pressed down, if you let go it turns off automatically.
Old 07-22-22, 02:44 AM
LeeSoFL
LeeSoFL's Avatar
Is the purpose of this momentary switch something you'd reveal to the gang? That's what I meant.
ATL350 (07-22-22)
Old 07-22-22, 03:38 AM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
The following 3 users liked this post by DaveGS4:
bootman (07-22-22), dklanecky1 (07-23-22), LexFinally (07-23-22)
Old 08-09-22, 08:07 PM
FreddyG
FreddyG's Avatar
Or a Nitrous button!
Quick Reply: Can I buy this button somewhere (dash blank)
