Es 2022 ac
10th Gear
Wondering if there is a way on ES 2022 to turn off air condition while keeping the fan on? I want to have a possibility to get air straight from outside withiout AC.
You have to go through the menu...
i see you're new. most of these questions are answered already over the years. =) So feel free to use the search feature
on my 2021, just reset the button to the left of the right temperature control. Choices are inside air, outside air and cooled air or none for either.
I keep it on auto and adjust the temperature. My understanding is that that keeps the dehumidifier on, which is desirable on rainy/muggy days, and the cooling toggles on/off depending upon the temperature setting compared with the set point.
10th Gear
Found it inside the climate settings. There's no button for it in the 2022 model. Apparently, you can only turn it off when the climate is not in auto mode. Thanks all.
