Beginner questions on the ES 250
Dear all,
I purchased a 2021 ES 250 AWD with the 2.5L 4Cyl motor for $40k after everything, it isn't a v6, but enough for my needs. Hopefully owners here can help me with some of the questions I have on this old-new car!
1. What octane of gas does it require? Google told me 87 minimum, sales told me premium (octane unclear)
2. The front emblem's clear glass cover is cracked, L/Certify says the safety feature works but won't replace it. Are there after market parts which I can jerry-rig onto the oem emblem?
3. What is the best way to accelerate if I am going to over take on the highway? I am afraid that just simply flooring the engines will hurt the motor, perhaps I need step on the gas in intervals?
4. Does the 2.5L 4Cyl have a name and reputation? Is it the same one that is in the Camrys?
Apologies if I seem ignorant, and thank you for reading!
1. Your car manual says 87 minimum.
2. Not sure, but I don't know if I'd trust aftermarket in this regard as it deals with safety features.
3. Like any other vehicle, gradual acceleration.
4. 2.5 L A25A-FKS I4 (also indicated in your car's manual)
Thank you for the reply, I realized that these details should be in the manual, but I actually don't have the car yet. Sorry for jumping ahead and asking.
EDIT: I have driven the Rav4 for a while and found its performance to be lacking during over takes, I suppose I will have to be gentle with the Lexus too when I am overtaking or passing.
1. Just use 87. Sure, you can use 91 or 93, but you're just wasting money for no reason.
2. Just buy an OEM emblem. It'll be a bit pricey, (I'm seeing $150-$200 from 30 seconds of searching), but aftermarket ones are usually cheap crappy plastic.
3. Floor it. You'll be fine. It's the same engine as my 2018 Camry, and I sold it at 102k miles flooring it when needed to. Drove like new the day I sold it and had 0 issues with it. It's a Toyota, not a Range Rover.
4. Yes. It's the same engine found in the Camry.
I haven't driven the rav4 but I imagine you'd drive your new 250 about the same. The ES is about as heavy, if not heavier, than the rav4 so however you drive now you'd most likely continue the same with the ES.
OP, I have test driven the ES250 as a loaner.
ES250 doesn't have good power for emergency overtaking.
However, it has adequate power, and smoothness and quietness for normal driving.
ES's weigh hundreds of pounds more than Camries, so the same 2.5 L engine must work much harder than in Camries.
Because ES's have more sound deadening, ES's are likely to be driven much harder than Camries again.
Thus, try not to constantly use wide throttle openings unless necessary, because this will cause the same engine to age much faster than in Camries.
Ultimately, bacause your ES250 weighs hundreds of pounds more than Camry, and has more sound insulation which encourages harder driving, your ES250’s motor will not be as bullet proof as Camry 2.5.
If one wishes to constantly drive hard, then either purchase a 2.5 L gasoline-electric hybrid or a 3.5 L V6.
If you have an emergency or whatever and you need to full throttle - then by all means - boot it...
Engine wear is caused by: dirty oil, dirty air, dirty fuel, overheating, overrevving, improper maintenance parts.
It does not seem that an engine pressed to work within its design limits would cause excessive wear.
The following 3 users liked this post by mcomer:
Don't be silly! If you read the oil change interval thread, engine wear is ONLY caused by 10K mile oil changes. LOL I digress...
landonm86 (10-08-22)
Dear all,
87. It's a Camry.
No jerry rigging
Floor it
Camry
As long as you're not redlining it, the only negative will be increased fuel consumption. I assume you're only doing these types over overtakes on the occasion, and not flooring it from every red light or trying to get around someone cause they're going 50 in a 45, etc.. So as long as you drive it like it's a Lexus ES, and not a BMW M3, you'll be fine. People don't buy Toyotas/Lexuseseseses to baby them, they buy them cause they can take whatever they throw at them.
